I need to cut 40+ moritses in maple (3/8″ w x 1.25″ d 2″ long). I have a long 3/8″ birds mouth mortising bit, but don’t know the proper procedure to cut with it. Deep plunging does not look like this bit’s forte. Should this bit used to skim off a little bit at a time (1/16 th ?) or should the mortise be hogged out with another bit/tool, and the birds mouth used to smooth the edges ?
Any help will be greatly appreciated.
Tom
Tom,
Either you or I are confused. A birds mouth bit is used to create positive registration and more glue area when doing coopered-style work, as seen here http://www.leevalley.com/wood/page.aspx?c=1&p=45160cat=1,46168,46174
Flair,
I've attached a crude sketch of the tip. It looks like a bird's mouth to me. I believe it is intended to do mortising.
Tom,I'm not sure what a MDI file is, but I can't open it. Charles' description of a mortising bit is accurate.Chris @ http://www.flairwoodwork.spaces.live.com(soon to be http://www.flairwoodworks.com)
Tom,
Typically what is referred to as a mortise bit is intended for shallow recesses like hinge mortises. For deep pocket mortises the best tool is probably the dedicated mortise machine which has a drill bit inside a square chisel. If you intend to use a router bit I would recommend an up cut spiral bit like the 75-106 (note that 1-1/4" is the max cut length with this bit and the cut should be made in multiple passes to avoid over stressing):
http://www.freudtools.com/p-63-up-spiral.aspx
Freud America, Inc.
Tom,
The mortising bits for the slot mortising attachment for my MM jointer/planer are called 'birds mouth', they are manufactured by Onsrud. Are these the bits you are talking about?
I haven't used the slot mortiser a lot, but the technique I used was to cut from left to right, in 1/8" incremental passes. Very clean cuts and definitely the way to have to cut many mortise joints..
Edited 3/17/2009 9:58 am ET by BOBABEUI
Been using horizontal slot mortisers for 25 years plus. I've tried the "birdsmouth bits". The actual name is Oscillating mortise bit. I find the 2 flute HSS endmills do a better job, have more size options and are cheaper. Look for the center cutting type for plunging but they work best if you go in 1/8" as you move side to side. The oscillating and endmills wotk best at around 5,000 rpm. Not for a router.
http://www.morriswoodtool.com/Tooling-Misc.htm#Oscillating Mortise Bit, Style 6HS
Edited 3/17/2009 10:55 am ET by RickL
Rick,Thanks.. The birds mouths 'came' with (kind of) the purchase of the slot mortiser.. They seem to work pretty good, but I will pick up a couple of HSS end mills to compare and contrast. The slot mortiser is a really cool addition my Minimax FS-41E jointer/planer..
Make sure they are two flute. Four flutes are like ripping with a cross cut blade. Bogs it down. Endmills are pretty inexpensive at http://www.use-enco.com and http://www.wttool.com
Thanks all. Tom
Boy, that's confusing.Chris @ http://www.flairwoodwork.spaces.live.com(soon to be http://www.flairwoodworks.com)
Thanks all (again).I tried the "oscilating bird's mouth" in my router at its lowest speed (5000 rpm), and made shallow (1/16") passes. This was in pine. Progress was slow but only had minor burning in the wood. This bit is HSS and shows a lot of pitch build up or burning on its two cutter tips. To do 40 mortises in maple not only be too slow to but I don't think this the bit will be able to stand up to the heat and harder wood. I ordered an upcut bit today.Tom
What router do you have that goes to 5,000 rpm??? Lowest I've seen is 8,000 rpm.
HSS in a router typically doesn't last long. I suspect the oscillating bit you bought was for a slot mortiser.
Rick,
I was wrong about that 5K rpm, 8000 is the lowest speed.Tom
http://www.felderusa.com/
They sell what you have.
