I’m so thrilled with the finish I have to share it.
I made a book case from a design picked up from Fine Woodworking.com and used a finish recipe found there also. I’m thrilled that I could get an inexpensive wood, birch, to get such a rich look. It was a recipe for finishing maple, but since birch & maple are somewhat similar woods, I took a chance.
If any one is interested, the wood is dyed Honey Amber, then tung oil & then garnet shellac. After experimenting, I put on 3 coats of dye, 2 coats of tung oil & 3 coats of garnet shellac.
I think it looks great. Please overlook the obvious mistakes in the photos.
Looks great. Nice work!
Amen to that inexpensive hardwood. I believe birch is often overlooked and underrated. I am working with some awesome birch veneers that were at the bottom of the price scale.
You are absolutely right about birch being underrated. Variation in the grain in birch give a great look by changing the luster as you look at the finished piece from different angles.
As I work the finishing process described above, I enjoy watching the beauty develop.
I'm going to try working with flame birch soon. I know it will look great.
Edited 5/13/2007 11:15 am ET by SwartzWuest
The first time I handplaned some I thought I missed some parts. It looked like a giant ripple going across the board, so real looking that I rubbed my hand over it to feel the bump, none there! Smooth as glass!
Anyone care to resize the 2 Meg photos for us dial-uppers?
Lee
Lee,
Here Ya go, man.
Bob,
You're a gentleman and scholar!
Lee
Bob was your reply what I thought it was?
SW,
Great looking finish and bookcase! I will make notes of your recipe and put it in the "things to try" file.
Lee
Any chance you could post the links for the finish recipe and design?
I found the article with the design but could not find the finishing article.
This is the link to the design article.
http://www.taunton.com/finewoodworking/ProjectsAndDesign/ProjectsAndDesignPDF.aspx?id=2801
If the link doesn't work, search under Steve Latta & open the article called "Bookshelves in a Day"
Thanks!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Nice book shelf!
Too weird, I have decided on that very same design for a shelf in my boy's room. Decided to use birch too. Been playing with finishes, tung oil and garnet shellac!
Will try your recipe on some scraps. I am considering trying some oxalic acid to attempt to remove some of the gray "staining" in the sap wood of these boards. (My goal is to even out the color contrast between the heart and sap wod; yet stay as clear as possible with the finish to show off the "inner light" and subtle curl.)
Max
SwartzW,
What kind of birch, yellow? I have several 100 bf of yellow flame and my sawyer friend called last night and has some curly white birch and some w/birdseye! Going to have a look tonight!
I've used birch for several projects. I agree it is somewhat overlooked as a material for furniture. It is hard, stable and takes a finish well.
I'm currently refinishing a birch gun stock. I mixed some Red Mahogany w/Walnut stain, about 1/3 to 2/3 respectively and applied 3 coats. Now am applying thin coats of Tru Oil finish on top.
My bench is made of birch also. I would bet your recipe would look nice on the white.
Edited 5/16/2007 7:04 am ET by KiddervilleAcres
Hi Bob,
Birch was often used in lieu of/ in combination with mahogany in rural New England furniture. I've seen several pieces with mahogany fronts and birch ends. With the right stain, it can be a passable imitation, although I wonder if the old time makers thought of it as a substitute, or just a domestic equivalent-- it is certainly pretty wood in its own right.
I don't know about other parts of the country but here in Oregon I've very rarily seen Yellow Birch. Which is a shame because it's a very attractive wood, my favorite Birch in fact. I would love to see what it looks like with a flame figuring.
Kevin,
All the pieces I have are rough cut so it's hard to see the figure. I have a scrap piece that I was using to test plane blades for sharpness, and there is some in a cabinet I made for chisels & planes in the woodshop.
I'll see if I can get some pics tonight after work.
KA,
The wood used was Sweet Birch (Betula lenta), also known as Black Birch, Cherry Birch, Mahogany Birch, River Birch, or Spice Birch
SW
Bob:Some of the people who live in the vicinity of my cabin in far northern Minnesota have floors made of paper birch. In fact, the old Central School 45 miles away in Grand Rapids has floors, stairs, and bannisters made of it (turn of the century 3-story Romanesque building with big central stairways). It wears very well and looks wonderful -- lighter than most floors and woodwork, and wigh enough color difference to be interesting.Joe
Morning Joe,
I just picked up 120 bf of rough cut White/Paper birch last night. Mostly curly with a little birdseye mixed in as well. Beautiful stuff. Next to cherry I think I've worked with nearly as much birch.
It machies well and is very stable. In fact, I've never had any reaction wood from birch.
Those old birch floors sound great.
If I recall the Birches are of medium hardness according to the wood handbook. Hardness similar to Cherry. I bet that floor has held up fairly well.
I have milled several thousand BF of white/paper birch lumber. While milling it it seems that much of it has figure to some degree, most commonly big wide curls/flame and real big eye's. It seems that most of the developed market considers it a "utility" wood, which is perplexing to me.
Max
Hi,
I thought I would add my recent experience to this topic. Here is my version of the FW "Bookshelves in a day" (Ha , I am SLOW more like "bookshelves in a couple of days")
Anyway the wood is Paper/White Birch. Wood was sanded to 320 grit.
TransTint Cherry dye went on first, gray abrasive pad was then used to knock down the raised grain. (Some blotching on one board only.) (Overall did a fine job of evening out the colors from sap wood to heart wood.)
Next, a real light coat of Boiled Linseed oil went on.
Next I Brushed two coats of Garnet Shellac, using a gray abrasive pad between coats.
Next I padded two coats of Blond Shellac on again using the gray abrasive before and after.
Finally a light coat of wax was applied.
max
lovely, MaxI'm new at this -- how did you make your materials list for this project?
