Hi guys,
I know this is going to sound a little weird, but I can’t think of anywhere better to get an answer.
I have a buddy who moved across the country and misses a certain pizza restaurant here. For laughs, I’d like to send him a slice of the pizza in the mail (just the pizza…with stamps….no box, no envelope).
So I’m hoping you guys can recommend a good way to seal it. I was thinking about dunking it in diluted elmer’s glue or using a clear spray lacquer. I was also thinking about dunking it into a fast dry polyurethane (like MinWax).
Ideally the first glue or lacquer would be liquidy and fast drying so that it can soak into the pizza and stiffen it up. Then I can apply a few more coats of clear lacquer on top of that. At some point I’ll write the address and stick on the stamps before giving it one final coat.
Do I win for strangest post ever on this forum? =) I promise it’s not a joke…. I really want to send him the pizza.
Thanks!
ah6tyfour,
Wow...so many questions before I can give you an answer...
maybe a two part epoxy?
ah6ty_4,
My first thought was to spray shellac on it, a fter addressing it (This part might be fun). Now you must remember that this prolly won't go through their mek-a-nikle mail sorter very well so will be subject to a lot of hand processing.
Anyway, spraying it with shellac prolly won't kill any unscrupulous mail person should the pizza be too tempting to, well, pass along through the system. And may avoid another of those postal moments. :-)
That's a much more difficult question.
I can't imagine anything that would work, that would retain the appearance, and that the Post Office (or FedEX or UPS) would accept. At the very least it wouild have to have the box--besides the labeling on the box would really define the Pizza. (And, even then you would have to lie about the contents.)
Leave the slice in the refrigerator for a week or so first; that will dehydrate it and firm it up to where the USPS might consider accepting it. Shellac is probably your best bet as an initial barrier coat. Then apply several coats of epoxy (the kind used for laying up fiberglass) to solidify it.
When I was in college, a friend of mine received a coconut in the mail from his mother (it was still in its husk, so about 10" in diameter), who at the time was working at the US military installation on Kwajalein Atoll in the South Pacific.
Love it! Sounds like someting I would do.
IMHO, however, no matter how you seal it, it's not going to be stable enough to mail because, well, because it's a slice of pizza. The well sealed slice will bend, break crumble and fall apart. Besides, there's no way the USPS is going to take it.
I suggest you seal it real well and then shrink wrap it to a piece of 1/4 ply cut to size and box it.
It won't make quite the impact, but it should still be a hoot!
Thanks for the replies! I was afraid everyone would just think I was some idiot and not bother to reply.I like the idea about letting it dehydrate in the fridge for a week. I've done that to slices I would have liked to eat and that thing was like a rock after a week =)So epoxy or shellac, given enough coats, should make the pizza pretty stiff right?I'm also going to try to keep it from molding so I'm going to bombard it with UV for 30 minutes to sterilize it (I work in a lab) and immediately get the first coat of shellac on it. That should kill all germs and keep new germs from getting to it. Who knows, it might last forever.Is there a substance that can seep into the pizza (if I were to submerge it into the substance for 30 minutes) and completely stiffen it as it dries? Diluted Gorilla Glue?KiddervilleAcres, thanks for the reminder about this needing to be hand-sorted. I'll double the postage + $1 stamp to make sure. And I will definitely seal the handwritten address. I'll probably write on after the first layer of shellac so I'll have a smooth surface to write on. Writing on the crust itself might be a bit difficult.Thanks for the ideas! Keep them coming!USPS is pretty forgiving (see Wired Magazine's "Return to Sender" contest) and I will probably drop it into a mail box instead of bringing it in. And I'll take a picture of it...my friend will have a good laugh knowing I tried.If a postal employee decides to...taste it for freshness, well...he deserves whats coming.... =D
Edited 5/8/2009 11:10 am ET by ah6tyfour
Hey man, after all the pressure workin in the woodshop, sweatin thru a glueup and all. Gotta have a wee bit of fun now and agin.
All work and no play makes Jack a dull boy ye know. Sumthin my grandpa used to say to my father when I acted up. Said it quite a lot too.
Edited 5/8/2009 11:48 pm ET by KiddervilleAcres
Actually I think Frank has the only possibility. Freeze it, shrink wrap it, and address and mail it. It will arrive broken in half at least, but will get there, but not intact.Gretchen
It is evident that you do not intend for the recipient to eat this pizza slice, so I would suggest that when the pizza is fresh, you carefully remove the toppings from the crust and insert a piece of 1/8" ply or like material in the middle for stiffness.
and now www.flairwoodworks.com)
Project update:I ended up going with a polyester casting resin from the craft store (Michaels). I was doing a google search for "liquid plastic" and it came up and seemed exactly what I needed. Liquid until the chemical reaction with the catalyst turns it into a clear plastic.I made up 20oz of it and poured it on the pizza so that the pizza was completely submerged. Half an hour later the liquid was starting to get noticeably thicker so I removed the pizza and let it rest at an angle for a few hours so the excess would drain off.It's still in the process of drying (I guess "curing at room temp" is a better description), but I think it worked. I poured the excess liquid back into the mixing container and noticed that I recovered about half of what I started with. That means a good 8-10oz of the liquid made it inside the pizza.The way the reaction works, any surface in contact with open air will stay tacky so I still need to go get a can of spray gloss to finish it up.If this works, I shall post a picture =)
Edited 5/10/2009 5:19 pm ET by ah6tyfour
64,
About 20 years ago I worked in the main post office here in San Antonio for a year. We had quite a few wooden post cards come through with no problem. Don't see why a properly dried and treated pizza should cause a problem. Go for it! Let us know how it works out.
GeorgeYou don't stop laughing because you grow old. You grow old because you stop laughing. - Michael Pritchard<!----><!----><!---->
Hi George,Thanks for the insight! Do you think I could take it to the post office counter and they would actually accept it?I was planning on dropping it into a mailbox since it seems like things that are slightly against USPS rules will still be allowed to go through once it's in the system. But pizza is definitely going to go over the 13oz first class limit so I'll have to send it priority. I guess I could still go get some $2 stamps and drop it in a mailbox with $6 in postage.Sorry to get off topic...as if the whole thread wasn't off-topic already...but at least my previous posts were regarding shellac and lacquer!
64,
I would take it to the counter. The post office handles all kinds of things you don't ordinarily think about as normal mail - live worms, live chickens, plants, etc. Go for it!
It needs to be taken to the counter in any case if it is over 14 oz. in weight. Since 9/11, you cannot put that in a post box. But it would need to be weighed and measured in any case.Gretchen
I just read an article on the craft of modern art restoration, and something in it actually pertains to what you're doing.
Because some modern artists use mediums like food, fats and fiber, art restorers have had to come up with ways of dealing with and preserving artwork made with those materials.
One of those methods is something call "plastination." That's a process where the fats in a material are removed (sometimes using a chemical like acetone) and replacing them with a plastic resin. Don't ask me how this is done (it probably involves something like a vacuum chamber). Interesting though, eh?
ZoltonIf you see a possum running around in here, kill it. It's not a pet. - Jackie Moon
And I get your idea ALO.. I loved it..
But if a REALLY good friend.. Why not just send him a REAL Pizza from them packed in dry-Ice! Now how to send the beer with it?
