Yo,
I have a contract to repair several exterior “historic doors” that have a rotted spot on the bottom rails;
Not too serious and an easy fix – I’ve used bondo and West System epoxy with very good results in the past. Now I want the best … what do you think?
What is the best way to repair rotten exterior door bottom rails-paint grade.
Thanks to all for your help and a special note:
I seem to be a hit and run kind of guy…and rarely run into the same folks nor do I have much time to chat-…get what I need to know and I’m down the road.
But, this forum has been extremely helpful to me and every time
I log on, I learn something new…after 30 years in the trade.
so cheers to all!!
silver
I've used Abatron with good results, drill some holes to allow it to penatrate. However, I don't know if its any different to West sys.
http://www.abatron.com/home002.htm
Silver,so long as the doors will be painted, I reccomend using 'Dutchmen" (No! not Amish wood workers )
Carefully choose wood of the same type for the patches.
Using your router, (Handheld) and the appropiate square or rectangular four sided open template, (Shaped like a thin picture frame ) rout out the damaged area wide and deep enough to remove all rotted material.
Note: the minimum north/south/east/west dimentions should be 2-3/4" wider than the proposed lenght/width of the 'Dutchman'
Use a 1/2" straight bit with a 6" base router and rout deep enough to remove all the damage.
Cut rectangular or square blocks to snugly fit the hollows.
Before gluing, round off the four radiouses (RADII?)to fit
(I first saw off some of each corner, then with a belt sander, radious the four corners.)
These blocks should be a bit thicker than the hollow so as to stand 'Proud'after glue up.
When glue has set, use two rails of the same thickness (Called 'Riding the rails') laid close to the patch, and lower the router bit in increments to shave' off the projecting wood to level it with the surface .
I've restored many old doors this way and they look great even today.
Ive occasionally installed dutchmen over or across a previous patch for odd shaped areas of damage. I f patching wood to be stained or naturally finished, orient the grain configurations to resemble the existing wood's grain. Stein
Edited 3/9/2004 9:55:12 PM ET by steinmetz
If it's joint failure, I'd replace the rail. Depending on the severity of the joint failure, a dutchman could do this, as stein said. If it's cosmetic damage, I'd stick with bondo- very strong and will hold screws well and easily paintable.
Edited 3/10/2004 10:03 am ET by JACKPLANE
I've previously done a historic restoration and I'm now on my third year restoring my own home (from foundation to chimneys)...In a "historic" restoration, it is important to keep as much of the original as possible (See the "Secretary of the Interior's Guidelines for Historic Restoration/Rehabilitation" if you are interested). Assuming this is going to be painted, the "best" system that I have used is by Smith & Company. I would suggest doing the following:
I've used these products with great success and have received good advice from the manufacturer. It is not cheap, but it does exactly what they claim it will do. In case it isn't obvious, I'm a big fan. Restore and preserve where possible.
Good luck with your project.
Edited 3/10/2004 2:11 pm ET by PNUTIII
Edited 3/10/2004 2:12 pm ET by PNUTIII
Thanks to all for the advice...right under my nose. I'm a low tech kind of guy and dutchmen appeal to me. Funny I didn't think of that but my head was into the best epoxy.
White pine on white pine with marine glue or West system around the edges topped with bondo...right on!
In another thread about ideas the consensus was that as thoughts on a "problem" are exchanged, we often see the obvious with new perspective.
btw, last night was Router class and I passed on the rout and remove process to a class of keen router newbies including riding the rails. What goes around goes around.
cheers,
silver
