Hello,
Does anyone have a good on-line source for bendy MDF, or bendy ply that is in the US?
Any suggestions would be greatly appreciated.
Sincerely,
E. Anderson
Hello,
Sincerely,
E. Anderson
Bendy??? As in flexable? Whatcha trying to do?
Boulter Plywood http://www.boulterplywood.com/product.htm carries bending birch plywood (look on the above page under "Specialty Plywood". I didn't see anything about bending MDF, but you could call them. The are in MA, homepage is http://www.boulterplywood.com/ .
Also, try a Google search http://www.google.com using "bending plywood" as your first search string.
The bendy MDF I have seen is about a 1/4 inch thick and kerfed on one side.
While they don't stock it, my local lumber/plywood supplier can get it if I ask for it. Try calling around to your local plywood suppliers.
Lomax
You might want to look for 3/8" fir bend- plywood. The veneers grains are all oriented in the same direction. rg
Anderson
I used bending ply for a sustrate on a round custom parts counter I made recently. It comes in 1/4" an 3/8". Can get it it so all the grain runs vertical or horizonal. Some call it wiggle board. We have two sources in the Atlanta area I am aware of. I suggest you call or drop by a local cabinet shop an ask. I bet they can direct you locally...
sarge..jt
