Just need a benchtop jointer or an inexpensive jointer with base. What are the community’s recommendations? I don’t want to spend more than $400.
You can get a pretty decent jointer for around $400. All of the benchtop models I've seen have lacked adjustability and mass. If you get one, it costs say $200, when you want to upgrade you're lucky to get $100.
Your profile doesn't list your location, but if you're in any kind of urban area, check out Craig's List. Grizzly sells a Woodstock open-stand jointer for $314 including shipping. The low-end Grizzly brand 6" would require you to go to $469 (including shipping). Home Depot's Ridgid 6" is $429, what's nice about that is you can check out the table flatness and stuff, return it if it doesn't check out.
It's just so likely that you'll want to upgrade a benchtop fairly soon, hard to see dropping a couple hundred$$ on one, IMHO.
Edited 2/28/2009 11:23 pm by forestgirl
I'm with FG on this one. Those things are a PIA. Even the small 6" are tough. Save a few pennies more and get either a used machine or go with a LN # 7 and winding sticks. I used that instead of the small delta 6" I had till I saved enough to get the Griz. Gave the delta to my brother.
(update) I had not been to the Grizz site for a while they have a 6" in the ball park.
http://www.grizzly.com/products/6-Jointer/G0452
Edited 3/1/2009 8:52 am by bones
Quite some time ago I attempted to use a friends benchtop jointer, if I recall it was 4" capacity. What I found was that because of its weight, or lack thereof we had to afix it to the bench to keep it from sliding around - not a good thing.
Then the bed height was too high to use comfortably/safely when affixed to the bench so would have needed to make a stand use.
Perhaps the biggest issue was that, again because of the 4" capacity, the pieces were so small that I/we simply didn't feel all warm and cumfy, safety wise, actually using it.
Even with appropriate stock handling devices there's something about passing small stock over those spinning blades that makes me nervous. It's that feeling I get when attempting to make a cut that my subconscious keeps telling me, "Bob - this is not safe"......................... Mebbe it's just me?
Edited 3/1/2009 8:26 am ET by KiddervilleAcres
In our area, there are almost always is a pretty decent 6" jointer on craigslist. I just picked up a 6" Jet for $400.
Good deal, I also have a 6" Jet. Bought it from my sawyer when he needed bigger iron as he also sells finished wood. I primarily use mine for dressing edges so don't need a wider one.
Another good thing about buying a used jointer is that you can see what you're buying befoe laying down your money. I was able to road test mine before buying it which, most likely you can't do when buying a new one.
If you're willing to wait and watch a bit, I find that old Delta/Homecraft 4" jointers come up with some regularity. These are very heavy for their size and built to last several lifetimes. They'll need new bearings, but there isn't a lot of rocket science to replace them. A typical price would be $75-100, sometimes less.
Pete
