Part of a basement renovation for a client will be a crafts area in which we’ll have cabinetry with commercially available solid maple workbench tops. On a previous project I bought my top from Grizzly. It came with a surface film finish but it was so scratched and dented I had no choice but to remove it, sand the top and then I finished it with Watco which worked well. I had planned to finish this project the same way but now the client has decided they would like a sink added for clean-up. What finish would be best to stand up to model glue, sharp tools and water? Thanks.
A concrete finished top would stand up to sharp tools quite well ;-}
A lot of people swear by the wax/oil finish. Dissolve a quantity of beeswax in an equal amount of turpentine, then mix it 50-50 with BLO. Apply generously, let it sit overnight, rub it down and apply more. About 3 coats usually does it and just about anything except tool dings can be scraped off. A wax gasket for a toilet is the best source for beeswax.
A film finish (lacquer, shellac, varnish, poly varnish) is not the way to finish a workbench top. A workbench is going to get dinged and film finishes will crack or craze or be otherwise damaged. Once a film finish is penetrated, it looses its effectiveness and adjacent areas begin to fail. No treatment is going to make a soft wood benchtop harder. I much favor a "in the wood finish". Here are two that lots of folks find effective.First, is an boiled linseed oil and wax finish. Sand the surface to 180 grit. Mix paraffin or bees wax into heated boiled linseed oil. USE A DOUBLE BOILER TO HEAT THE OIL. The ratio is not critical but about 5-6 parts of boiled linseed oil in a double boiler with one part paraffin or beeswax shaved in. Take it off the stove. Thin this mixture about 50/50 with mineral spirits to make a heavy cream like liquid. Apply this mixture to the benchtop liberally and allow to set overnight. Do it again the next day and again the following day if the top continues to absorb it. After a final overnight, lightly scrape off any excess wax and buff. This finish will minimize the absorbsion of any water and you can use a damp rag to wipe up any glue excess. Dried glue will pop right off the surface. Renewal or repair is easy. Just use a scraper to remove and hardened stuff, wipe down with mineral spirits using a 3/0 steel wool pad (a non-woven gray abrasive pad is better), wipe off the gunk and apply another coat of mineral oil/wax mixture.My personal preference is for an oil/varnish mixture treatment. Either use Minwax Tung Oil Finish, Minwax Antique oil or a homebrew of equal parts of boiled linseed oil, your favorite varnish or poly varnish and mineral spirits. Sand the benchtop up to 180 grit. Apply the mixture heavily and keep it wet for 15-30 minutes. Wipe off any excess completely. Let it dry overnight and the next day, apply another coat using a gray non-woven abrasive pad. Let it set and then wipe off any excess. Let this dry 48-72 hours. To prevent glue from sticking apply a coat of furniture paste wax and you're done. This treatment is somewhat more protective than the wax and mineral oil as the varnish component adds some protection from not only water both some other chemicals also. The waxing makes the surface a little more impervious to water so you can wipe up any liquid adhesive. It also allows hardened wax to be scraped off. Repair and renewal is easy. Just go throught the same scraping, wiping down with mineral spirits and reapplication of the BLO/varnish/mineral spirits mixture and an application of paste wax.Both of the above treatments are quite protective but are easy to maintain and renew. They do not fail when the surface takes a ding.Howie.........
