Hello, I have been trying to find the right balance between cost & quality on a belt/disk sander purchase. I am definitely a guy that believes in getting the best tool available and not skimping to save a few bucks & regret it later. Will I use a belt/disk sander combo enough to justify the cost? I have a spindle sander which I love & use all the time. Just for reference, I make pretty basic stuff, ie jewelry boxes, cutting boards, clocks, & small tables. Some of you out there love using the belt/disk sander? Brand for $400 or less possible?? Thanks…Price breakpoint? Mike
I used to have a belt/disk sander combo, a cheap one. The disk part was okay but the belt part wasn't. I bought the Ridgid oscillating edge/belt, spindle sander. I can use it like a disk sander by placing a miter gauge in the slot to secure the work piece. The table angle is adjustable and switching from belt to spindle is easy. Dust collection is not bad. The sander goes for about $200. You may find something you'll like better, but I don't think you'll come close to the price. One of the woodworking magazines rated it best over-all. I don't remember which one, but I'll try to locate it tomorrow, if I remember.
I use mine often and haven't regretted the purchase.
You'll get more opinions tomorrow so you'll have more ideas.
Good shopping,
Jim
Thanks Jim !!
I have seen that sander as well. I would agree with the value for the price. I think I will take your advice. I Appreciate it.
Check out the Delta. I bought one about ten years ago and have no regrets. I did add a graphite sheet behind the belt to reduce friction. I'm no fan of Delta equipment, but this is a cut above weekender quality, although Delta may offer several models. Can't remember the price. It has a capability for a pneumatic accessory. The stand is very sturdy. I'd buy one again.
Thank you much!! I will check out as well.
Since I already have a couple of pulley-driven disc sander units, I build my own belt sander platform that allows me to use both the flat and the rounded end:
Blocks hold the handle and knob:
And, a carriage bold adjuster below adjusts for square:
It obviously doesn't oscillate, but scrap materials were cheaper than the commercial units.
That is Sweet!!!! Very nice. I might try that. Thanks!!!
Brilliant minds can think alike. I modified this inexpensive craftsman 6 x 36 belt disk sander by removeing the useless fence and flipping it on it's side so it could actually be used as an edge sander. Obviously the table does no oscilate but it is adjustable in hieght so you don't wear out just one spot on the belt. I've got it hooked up to a shop vac. I use this tool all the time and for about $120 how can you go wrong. Well, I guess you can as I tried this same setup with a Ryobi sander first and it actually caught on fire. Faulty wiring in the motor. Uhmm, how do you post a photo on this reply?
