Can some kind sole out there pleeese tell me why a Certain Fellow, whose name is connected with a monthly list, gets a few Bedrock #601 planes made (note: he gets them made) and then asks $695 for one?
I ask this question because a)the price is a lot more than a far more functional practical Lie Nielsen plane costing far less but being several times the size and weight? and b)it is not a collector item .
I don’t need to be told “because someone will buy it”, neither am asking for a flambe- I saw the advert and those questions came to mind.
Mel: a short precis of a precis of your initial answer will suffice, and omit the Chinese angle,the price,and the fact that it is just a tool. (or is it?)
Lataxe: something humorous with north country accent and grammar is called for.
Larry: no need to compare these with wooden planes, and go easy on the arm chair pilots.Give us an estimation of the amount of sole wear around the mouth front after you have warmed it up some.
Ray: If you can compose your answer in the form of a limerick with no more than two puns , this will do.
Charles: you can bollock us all out, as per normal.If you come with yet another name then be sure to disguise your literary style-or I will identify you as usual.
Derek: let us know when you have examined it in detail, but your findings must be confined to this forum only and not broadcast on all channels.
Roc: can you confirm that the handles are Bubinga, and be sure to only speak to those persons whom you know.
Philip Marcou
I'm sure you already know that all 601 bedrock planes are "originals" and not reproductions since Stanley never made a 601. :) Have you considered making a 600 1/2? People who collect the bedrock series will then need to buy one to have a complete set.
Ben,
Good idea with the 6001/2: then Mr Leaches's son can consign them all to the melting plant, sort of like Dad likes to burn all transitionals (;)Philip Marcou
I'd love to know how many he's sold. I've got MUCH better things to do with my $700. Leach has always responded promptly to my questions. I think he's just taking advantage of the collector's tendencies. Tom
Philip - Acutally, these are collector's items. They are not intended to be used (though I'm sure they could be, should someone so desire). Many things on the antiques market are collectables, whether or not they're actually antiques.
There isn't any real functional reason why a Lie-Nielsen 2006 anniversary 4-1/2 in bronze is $500-$800 better than an iron 4-1/2 with a HAF, but they were very limited in production, they're pretty, and according to L-N, they will never be made again, so they're collector's items and bring about $1000 on fleabay, regardless of the fact that they're 3 years old.
I am with you until you say "they will never be made again".The 601 has been made in small runs fairly regularly as far as I know, so do those conditions still apply?Philip Marcou
Hmm - No, I was referring to the L-N 4-1/2 bronze smoother as "never made again". So far as I know, that doesn't apply to Patrick's plane. But I was sort of ticking off the things that make up a collector's item: interest, desirability, and rarity.
In Patrick's case, I think it's probably more of a case of "filling out" a collection of BedRock planes - there's always an interest on the collector's market of a "one of each kind", and he's filling this desire. Naturally, I suspect that these (the 601's) will always be relatively uncommon no matter how long he decides to make them, as his production is just not enough to generate thousands and thousands of examples.
Another reason for the price, though, is "comparison shopping". A very good condition Stanely #1 brings thousands and thousands, so a collector can have a repro (even an "improved" repro) for a whole lot less. This sort of thing also drives some of the reproduction 18th century furniture market - you can have a nearly unobtainable piece of "John Townsend Newport" furniture reproduced for between a few thousand and a few ten thousand dollars, where an original, if obtainable, would be in the millions.
Philip,
I assume he just had profit in mind. He's pretty tuned in to the collector market and was probably filling a niche as he saw one.
The price, while I certainly would never buy one, I feel is reasonable given the cost of tooling up and the limited number that must have been made. If he was making millions of them the cost would probably be considerably less.
Best regards,
Mack
"Close enough for government work=measured with a micrometer, marked with chalk and cut with an axe"
Hi philip,
You asked for it:
There was a certain Kiwi, Down Under,
Who denounced cloned Bedrock prices as plunder.
"Small batches, re-sold,"
he sniffed, "Not even old.
Why, next, he'll be stealing my thunder!"
Thanks Ray, I knew you would come up with the goods.
I think I must do a 1/5 scale S20 now....be a snip at 15K.Philip Marcou
