All,
I am new to woodworking (2 wks)and have at least one question for now:
What is the best method of joining a cabinet side panel to a face frame?
I have tried routing out the face frame for the width of the side panel & I have seen the use of tongue & groove & a butt joint.
So I guess that I am looking for advice.
thanks,
dlb
The undisciplined life is not worth examining.
Could you clarify what you are doing?
Do you mean you have a face frame and are looking for ways to attach it to a cabinet or a run of cabinets?
If yes to the above, glue and finishing nails would be the easiest method -- if you don't mind having nail holes (which can be filled and pretty much obscured, especially if the face frame is stained).
A biscuit joiner is another choice, as long as you can clamp the frame to the cabinets whilst the glue dries.
I am building a cabinet with a face frame and sides made of plywood. I am looking for suggestions on attaching the sides to the face frames. I like the idea of T & G due to minimal cutting, amount of glueing surface, tightness of fit and the joint between the ff & sides.
thanks,
dlb
I use pocket screws in places where the won't be seen such as lowers (bank of drawers/sink cabinet with plugs) and biscuits in places where the will be seen such as uppers.
_________________________________
Michael in San Jose
"In all affairs it's a healthy thing now and then to hang a question mark on the things you have long taken for granted." Bertrand Russell
Depending on the situation, you can biscuit, T&G, pocket screw, butt joint & pin. I use the best method for the application. Most of my work uses biscuits or T&G- I won't allow nail holes on my FF's at the level of quality that I produce.
glue.
it is an edge joint....when joining a glue up panel, all you need is a well prepared joint, some good glue and some good clamps.
For attaching the face frame to the carcass, same applies.
On the neverending quest for wood.
the first time i did a face frame i used dowels. this worked good, as long as you use a good doweling jig you know well. since then i've used mortise and tenon and crosslap joinery sometime. recently i been using the biscuit joiner for wood and ply. i think this is the best way (for ease of construction & durabilty).
