Hi everyone . I need to make some 12 foot bamboo counters and can find only 8 foot veneers or panels. I also thought I can try some square edge flooring on a particle board core . Is a butt seam with veneer or 1/4 ” plywood possible ( using a router) or is there anyone who makes 12 foot veneers? Any suggestions? The counter is a u shape and will probably miter the corners unless there are other ways that will look decent. Thank you.
jp , You could run the grain in the 24" direction and make and hide your seams with the grain . Some edge treatment is often used either way the grain goes .
dusty
