I have been contemplating Baltic birch as a bookshelf material with a front and back edge of 1.5 inch birch. The books going on the shelf are heavier reference books over a 43 inch span. The shelves will be 10 inches deep. I read in the posts that I searched that plywood sags more than softwood over the same span. Is this true of multiply baltic birch? It seems to have significantly less sag in the shop, but I don’t want to be called back to replace the shelves. They are to be atttatched on three sides to the wall. Any input?
luke
One option is to double up on the ply - 2 layers of 3/4" edged by the 1.5" birch might work. 43" is a long span. I once used an 3/4" x 1.5" solid wood upright centered vertically on a long span and just notched @ each shelf. Effectively cuts the span in half and still leaves it relatively open.
Bob
For heavy books your design is just a bit wimpy for that span. There are lots of options to beef them up a little. Stair tread material would be adequate. You could add a piece of steel tubing below the front of the shelf (behind the shelf facing). You could use a heavier facing... say 1 1/2 inch X 2 inch (rabbeted for the shelf). You might add a center brace to the shelf bottoms. If you can get it you could use 1 inch BB ply I think that would do it too. I have liked using 6/4 lumber (usually poplar) for such things and then they do not need a facing.
What do you think of 1 inch baltic birch with 1.5X1.5 birch edging?
I was planning to tongue and groove it together.
luke
While plywood does sag, you did not mention whether the rear and side edges would allow support cleats; I have had success up to 48" x 12" using support cleats, a 3/4 x 1 1/2" solid lumber rabbeted front edge attache with glue & biscuits or dowels; and have even added vertcal plywood ribs horizontally under the center of the shelf when weight requires. I would be sure to use good joinery and a good pva glue.
I apologize for the lack of details. The intention is to have full length cleats on 3 sides. The Baltic birch would be 1 inch thick with a tongue and groove 1.5inch x1.5inch birch strip along the front. I plan to do my best with the joinery. The shelf is 43 inches wide by 10 inches deep. The load would be just shy of 120 lbs max I believe. (Normal lbs per foot is 20 to 25. Because these are substantial books I am going with 35 lbs/foot)
luke
Edited 10/4/2006 6:45 pm ET by quietude
http://www.woodbin.com/calcs/sagulator.htm
Per your description, you have plenty of strength. The URL above gives sag based on the shelf being supported on the ends. You will greatly increase its load-bearing ability by cleating the rear of the shelf, and the 1.5" hardwood leading edge also adds a lot of strength.
I was about to post that link as well.
Also a few notes/rules of thumb to stregthen a shelf:
Make it deeper
make the span shorter
Adding a hardwood strip to the edge can increase strength 2-3x
doubling the thickness can increase strength 4x
You can add a hardwood strip at the read as well as the front, with it being 2x the thickness of the shelf
" There'll be no living with her now" - Captain Jack Sparrow
I think that will do fine. Those should hold up plenty of books.
Thanks for your help.
luke
One thing I have done on long shelves like yours is to glue a board on the front edge. I usually glue a piece of hardwood which is 3/4" X 1.5" and then have a center support on the back of the cabinet.
