I installed some drawers about 8 years ago underneath a platform bed, with ball bearing drawer slides. Now, all of a sudden, one of the drawers won’t stay shut. Do I need to replace the slides?
Well you need to take it apart and figure out what is wrong. It could be worn out, or in need of cleaning and lubrication, or there's a sock jammed behind the drawer.
John W.
Exactly which brand or series slides did you use ?
As John said I would look for an obstruction preventing the drawer from closing , take a look .
Every now and then the race or bearing holder ( usually black plastic ) will let loose and fail on the lower duty 100lb ball bearing slides . The other possibility is the slide is out of it's own track perhaps on one side only , if you have not yet you need to pull it out all the way the problem may be clear at that point.
I have built many large full extension drawers and what I have noticed is sometimes when a drawer is only pulled out say half way and then closed for most of it's use the slides can build up some resistance to stay shut , simply extend the drawer out all the way and an extra little tug to make sure its all out will often times clear the problem .
Depending on the brand there may also be a friction catch at the rear or the front that may be the culprit .
good luck dusty
Is there any chance your house tilted to the left? <g>
Hey, that was going to be my question!
Yes, runners can wear out - but not all at the same time. There is something else wrong.
Did something shake or move the bed recently (grin)?
You installed your drawers 8 years ago under your bed!? And now they won't stay shut?
By all means don't venture out to the mall, well, perhaps a strip mall might be OK.
Edited 4/8/2008 12:25 pm ET by KiddervilleAcres
