I’m presently making a 30″ X 48″ coffee table. The table apron will be veneered with curly maple. The curl stripes will run vertically. I also want the legs veneered. They will be 2 -3/4″ in cross section. Is it asthetically o.k. to run the curly maple on the legs horizontally? If I try to run curl stripes vertically, I would have to butt the veneer together. My veneer pieces are only 5 inches wide. You will probably see the seam/joint if I run the curl stripes vertical. What is standard practice to this application.
Don
Standard practice is to have horizontal curly stripes on the legs, since that's the way they would be if the leg were solid wood.
Personal aesthetic opinion: I think curly maple on skinny table legs should be outlawed. I'd use straight-grained (rift-sawn if possible) maple instead.
I am gonna have to echo Steve here. It may look visually different, but that will most likely translate into visually confusing. From a mechanical standpoint, running the leg veneer horizontal will create quite a few edge joints that have the potential to fail. Using either solid curly maple or like Steve said, rift sawn, will marry splendidly with a veneered apron.
Adam
