I would like to add some brown colour to some water-based stain in order to better match some existing trim. Are there any good ways to do this with found items rather than buying more stain and mixing? I was thinking of running the stain through a coffee filter, grounds included.
Ideas?
Thanks in advance
How much did you spend on the trim, and how much do you value your work? Cost of brown dye seems pretty minor by comparison.
More important, would you be creating compatibility problems with intended following coats of finish? What effect would it have on the existing color?
