To All
Regarding air drying wood, specifically north American hard wood, does anyone know if the one year per 1″ of thickness is influenced by the lumber’s other dimensions?
For instance, if you were to compare a plank 3″ thick x 8″ wide x 8′ long with one 3″ thick x 3″ wide x 12″ long would they require the same amount of time?
Bill
Basically the only determinate of drying time is the thickness of the wood. Width and length are not relevant. Of course, other non-wood things affect it also. Temperature, relative humidity, air flow, etc. all have an affect on the length of time to dry. Different species take differing times to cure also.
The "one year per inch of thickness" is a very rough approximation at best.
Howard,I saw your post regarding air drying wood and I'm hoping you might shed some light on my problem. I purchased some 2x12 yellow pine -"scaffold plank" - to make a table. After the fact I realized that the KD19 stamped on it indicates it was kiln dried to 19%. I have it stickered in my garage in Maryland. How long do you think I might need to wait before it gets to 12%? Or - what do you think would happen to a table top if I were to glue it up at 19%? Any help you can give would be a great help. Thanks.Ben Winkler
With respect to Howard, his answer is close, but not quite on the money. Most of the moisture is going to wick along the fibers of the wood and evaporate from the end grain, so in a sense the length over a few feet won't matter too much. However, the rate at which the wood will dry is a ratio between the surface area of the end grain (and to a small extent, the face and side grain) and the total volume of the piece. So in the example you give, you could expect that the small piece will dry faster than the larger piece by virtue of the fact that the ratio of the volume to the surface area is much smaller with the smaller piece of wood. That's partially why turners can often wait a bit less time for a rough-turned green blank to dry out.
And, of course, leaving the wood outdoors in a humid climate is going to mean a much slower drying cycle than that same wood left outdoors in a place like New Mexico.
