In the ice storm of 2008 we had a very large cherry tree come down from the storm. I had it cut up and “stickered” in a drying shed. My moisture content meter [Ryobi] reads 8%, is that dry enough to work with? There are some 4″ slabs that seem very slow to come down, is that unusual? There are at 12% and holding. Any ideas out there about what I can expect ’til they are ready to be worked?
Lumber moisture content
Typical air dry time is 1 year / inch of thickness. You can expect those 4" thick slabs to be ready in a couple more years. I consider 8% to be just fine, but you should have an idea where the wood is going to be used before you make that call. The two main reasons kiln dried is "better" than air dried are:
1.) Kiln drying lumber kills any bugs in the wood
2.) Modern HVAC systems tend to keep the humidity in modern homes much lower than exterior ambient. So, air dried wood can continue to shrink and check more so than kiln dried lumber. On the flip side, kiln dried lumber stored in a barn will tend to absorb moisture back up to "ambient" so...
Since it looks like you're in New Hampshire, I'd get to it.
Also, the higher moisture content big stuff may actually be better for turning now rather than fully dry. I'm not a turner, but I know a lot of turners turn wood that's green and then let it finish drying in a controlled manner (storing it in a plastic bag, etc.).
http://www.peterchild.co.uk/info1/green.htm
air-dried cherry wood
Hi, Thanks for your advice and information on my cherry wood. I was contacted by a turner and as you mentioned, he was most interested in the slabs. Well, thanks again for help. jrmdog
Moisture
The easy way to see if 8% is dry enough is compare it to some wood in your shop. If you have some kiln or air dried lumber that has been in your shop for months or years check it or wood in your house. There is no magic number it just needs to be close to what "seasoned" wood in your shop or house. There are lots of downside to kiln dried lumber if it isn't done right...
air drying cherry
Thanks for note on the M/C on the cherry. I will take your advice and check around with my meter. Also, if you don't mind my asking, what do you mean by the drawbacks to kiln dried wood which was incorrectly dried? Thanks again for your insight. jrmdog
