I’m looking to get a new compressor…I don’t need it all the time, but I don’t have one yet, so why not? I saw a P-C in Tool Crib that ran 5.3 CFM at 90 PSI, but what does that translate to at 100 PSI, or 110? Does P-C make good compressors? If not, recommend me a good quality one.
Young, poor, and eager to learn
I own the PC pancake compressor that comes in a kit with the 16 g finish nailer. It is LOUD, takes for ever to fill at the start of the day, and kicks in after every 7-10 15g nails if i'm nailing trim.
Is it going to be used in a shop? or job site?
If it's for the shop were your using brads then You mite want to look at the 1/2 HP by Senco. They are quiet and some of the guys over at break time use them. If you can wait, then save up the $'s (320.00) and get a Thomas 1 1/4 HP Ultra Air-Pac compressor. It's a pancake model. For $350 they have a twin tank 2 HP. They are real quiet! I'm getting one myself for interior work!
Search Breaktime @ FHB there are a ton of post's on compressors just search for them. DON'T start a new post on the subject over there, they will give you a hard time LOL. Just go to the bottom of the page of messages and you will see the search for box.
Remember if you buy the right one you pay for it once!. If you by the wrong one you pay for it every day!
Good Luck
All Things Wood!
Stephen Prunier Carpentry
I guess I should be more specific...The ones I was looking at were the 3 HP, 4-Gal twin stack or pancake compressor. I don't know which is better between twin stack and pancake, either. I would like to be able to run at least 1 framing nailer, maybe 2.
Edited 3/11/2005 10:14 am ET by SBerruezo
I have a Dewalt D555155, 1.2 HP 4 gln. It's very heavy (61 lbs). Works well though. Would have gone smaller for the work I do (mostly finish work).
Edited 3/18/2005 11:49 am ET by Jay
Give Thomas a look- in particular the T-2820ST and the T-200ST (which I have)models............ imho the best portable compressors on the market; reliable, very quiet, runs fine off a 15 amp circuit and oiless. http://www.thomasairpac.com/ Only other brand I'd consider would be Rol-Air. http://www.rolair.net/
Edited 3/19/2005 10:25 am ET by jc
The PC is a good compressor and you would be able to run 2 Framers off of that compressor. If you are going to be using this compressor on a job site every day definitly get a maintenance compressor, meaning you have to change the oil. If you maintain it it will last considerably longer than the maintenance free ones. The difference between a Pancake and a two tank is application and air capacity. Pancake will work for smaller applications like finish guns and brad nailers where the dual tank will work for framers and roofers. The pancake kits are designed for the homeowner.
