I have an opportunity to purchase a little used Jet Drum Sander. A Jet 16-32 Plus.
Here is a link to one.
http://www.rockler.com/product.cfm?page=17142&filter=performax%20drum%20sander
Anyone have any idea how good the model is? Know of any problems or shortcomings?
Alan – planesaw
I have had one for a couple of years now and don't know how I got along with out it. It is not a thickness machine and when used as a finish sander you will not have a problem. I run all my stock that has been through the thickness planer to get out the planer marks. I remove about .015" per pass per side using 120 or 150 grit. Sanding woods with resin such as pine clogs up the paper pretty fast. I basically work with poplar, cherry, walnut and oaks, these cause no problems with loading up. I have had no mechanical problems with the machine and I have processed a couple of thousand feet of wood with one piece of sand paper. You will need a good dust collection system as it generates a lot of fine dust. I finally got an Onieda dust deputy cyclone and connected it to a 5hp vac. and virtually have no dust in the shop. I am very satisfied with Powermatic 16/32 and would not hesitate to purchase it. Good luck
mrbird
Thanks for the detail and recommendation. A friend got one about 7 years, has only used it 7 or 8 times and said they just didn't see hanging on to it. I am considering whether or not I want to buy it.
Alan - planesaw
What are you planning on using it for? I have done a bit of research over the past few weeks on a drum sander for thickness sanding after re-sawing. You may find this thread of help:
http://forums.taunton.com/n/mb/message.asp?webtag=fw-knots&msg=41574.1
I have heard mixed reviews of this design (and the Performax) where the cantilever head is adjustable.
In contrast, Delta claims the new 31-260X is designed as a thickness sander. It looks as if the head is fixed and the table is adjustable. This makes more sense as a stronger design less likely to flex under load.
Greg
Exo 35:30-35
Greg,
Thanks for your thoughts and the link. I know no tool is perfect, but it helps to learn the pros and cons before I buy (or don't).
Alan - planesaw
I love mine.
Regards,Sean
