I just used transtint dye for the first time. I did two coats, sanding between coats to highlight the grain. The second coat is now dry and I want to apply a shellac sealer. Should I do anything before applying the shellac? The dye was dissolved in alcohol, so I was wondering if I should be concerned about the shellac re-dissolving any of the dye and making the finish muddy.
re-dissolving
You should be OK with shellac over alcohol based dye stain. Just mist on a few coats lightly before a heavy wet coat.
SA
Alcohol over alcohol
Applying shellac, which is disolved in alcohol, over your alcohol-based Transtint dye is going to cause you some pain, I think. As the other reply noted, if you can mist a coat or two on before brushing on or spraying on a heavier coat, you may be OK. But the alcohol in the shellac is going to redissolve the dye.
Regardless of how this project turns out, I would suggest you switch to water-based powder dyes for your next project. You'll find a wider variety of colors and the alcohol in the shellac won't cause problems with the powdered dye.
Good luck.
Dye
I don't think you will have any problem with a topcoat of shellac over dye applied over bare wood. Once the water or alcohol has evaporated the dye has penetrated into the wood. If you were using say, a waterbase dye over a shellac washcoat to prevent blotching and then attempted to use an alchol base topcoat then you would have problems as the topcoat would dissolve the barrier coat.
But I can give you some indisputable and invaluable advice: When in ANY doubt when it comes to finishing, simply make a test panel and apply your finish schedule to it in advance, to do otherwise is a suckers bet.
Good Luck
Rob
Rob,
What you described is what I experienced. I brushed on some shellac and everything seemed to stay put. I had to grin when I read the second part of your reply. My inquiry was in fact for my test panel. I'm experimenting on a piece of curly maple, and I will only get probably 4-5 test panels before I'm out of material, so I want to make every test count!
