Specifically, I’d like to glue a nickel to a piece of maple. Recessed the hole for the nickel and tried using Gorilla Glue, but it didn’t hold so well. Any suggestions?
Edited 3/28/2005 5:15 pm ET by COLEMAN654
Dear Coleman654,
Have done metal in wood much as you describe, using a small amount of silicon. Lightly pressed, and let it dry before cleaning any excess. Let it dry overnight.
Then, some wood-filler or even Bondo can be added for a no-gap look and further retention.
-mbl-
What kind of stress is the joint under that would make the nickel come loose? I would expect Gorilla Glue to work very well if the nickel and the wood were both clean. GG needs a little moisture to cure, so slightly dampening the bottom of the hole before applying the glue would be good. Also, GG needs to be clamped fairly firmly. Otherwise it will foam up and push the pieces apart. Doesn't take a lot of pressure, just enough to keep the parts from moving.
epoxy.
Ditto --- epoxy.
I've had success with epoxy, if the surface of the metal is roughed up first.
Edited 3/28/2005 6:50 pm ET by BarryO
You are absolutely right about roughing up the surface of the metal; I should have added that, and I'm glad you did.
Body fill. It's designed to stick to metal and works well on wood.(it's polyester with a filler to thicken it) Cheaper than epoxy but Epoxy will also work well.
The Professional Termite
Does epoxy foam and/or expand like Gorilla Glue? There won't be any significant stress, at least on a regular basis, that would cause the nickel to work loose. What I'm trying to protect against is the impact of a drop that might jar it loose. Thanks for all the suggestions.
Epoxies do not foam and expand (like polyurethane glues do).
