On this side of the pond due to the credit crunch a few of the larger kitchen manufacturers have gone bust and I have now been approached by two prospective clients to quote for supply and fitting of bespoke kitchens.
Both potential commissions have 20 cabinets, 20 doors and 12 drawers which is a monumental finishing task. I have considered buying a Fuji Spray system and could accomodate this in my existing workshop if I spray acrylic (water based) varnish, but due to Health & Safety rules could not spray Pre Cat or AC lacquer.
Anyone out there used water based varnish on kitchen units before? The promotional blurb all say “hardwearing” but i wonder whether it can withstand kitchen grease, cleaners etc.
Any advice would be helpful.
Regards
Guy
Hey Guy,
Here in the states the standard kitchen finish is conversion varnish. If I could not use that, I would use a high solids lacquer. In my opinion a water base finish is not hard enough to hold up to wear and tare of kitchen use/abuse.
John
Thanks for the response. I suspected that and will perhaps have to use the services of a professional spraying company.
Look for a "KCMA Certified" finish. Ask your suppliers.
http://www.kcma.org/index.cfm?fuseaction=Visitors.Performance
I did one about 9 or 10 years ago now -- worked fine and still looks great. No signs of wear yet.
IIRC, I used my favorite finishing schedule -- a coat of Watco (to avoid the "cold" poly look), let it dry for at least two full days, then poly. I used an HVLP unit for spraying.
Mike Hennessy
Pittsburgh, PA
