I have found a few older Unisaws available recently, but they are 3 phase. Can I simply purchase a single phase motor and replace the 3 phase? This seems simpler to me than all the converter issues…
lostcreek
No, you will also need to replace the starter/switch.
I put an old Allen-Bradley 3 phase starter with appropriate new heaters on my 240V single phase jointer. Only used two of the 3 terminals, works fine.Work Safe, Count to 10 when your done for the day !!
Bruce S.
Simplest is to use a VFD as it takes care of the switch issue. If you gop with a new motor you can use the old switch. A new coil, new heaters and rewiring will take care of it.
http://www.factorymation.com/s.nl/it.A/id.198/.f?category=32
Call the tech and give him the specs. Should be able to get one for under $300 for 3 hp.
Edited 7/22/2008 8:11 am ET by RickL
A VFD is a good choice, but you CANNOT place a switch* between the drive and the motor, if it is done and power is interrupted between them you run a strong chance of ruining the VFD.BTW I paid less then $350.00 for a 3 HP single phase motor for a unisaw including shipping,another note is mag starter did have to be replaced due to machine being a 480 volt machine & starter was sized for it so it was undersized for 240 volts.
* You can use existing 3 wire control circuit but the starter needs to be removed.
I would not buy any current Delta machines now, as they are just Chinese peanut butter cast iron throwaway junk, a "vintage" machine is a better choice offering much higher quality then whats now avail. .
I'm well aware of the switch not being used with a VFD. The VFD is the switch.
I recently replaced my old phase converter with a brand new one from American Rotary. After a few months of use, I can tell you that I'm very pleased with the purchase. I spent less than $500.00, including terminals and wire, and it took only about 2 hours to wire it up. They give a great diagram (wiring for dummies), and it comes with it's own starter switch.
The money you save buying a 3 phase machine will more than pay for the converter.
The main problem with switching motors is that the Unisaw has a special motor with welded brackets on the casing side. I think there is one or two companies that make replacement motors in the $3-400.00 range. I opted to go the rotary phase route 10 yrs. ago and have 4 machines hooked up to it.
DavidW
