18g and 22/23g brad nailer/pinner advice
Can anyone give me opinions on 18gauge and 23/23gauge air pinners? I’d like to replace my cheap generic Chaiwanese nailer with a better quality one, preferably one with a soft tip and oilless. I’ve heard that Senco do an oilless 18gauge brad nailer. Has any one tried this? The 23gauge would be for use on small mouldingfs, etc
Scrit
Bostitch make a very good oil less brad nailer 18 gauge. The do not make an pin nailer yet, I've used the brad nailer and got good results with it. It will shoot 5/8 to 2in. brads. see attached web site.
http://www.stanleybostitch.com/default.asp?CATEGORY=BOS%5FFINISH%5FAND%5FTRIM%5FNAILER&TYPE=PRODUCT&PARTNUMBER=BT200K-2&SDesc=Oil+Free+Brad+Nailer+Kit
I have a 23ga senco and like it, no problems. Perfect for what it does.
I also have 3 Dewalt, 1 PC, 1 Senco 18 ga nailers Like the Dewalt then PC then Senco (but I may have a bad one). Make sure to get the 2" one.
We become by effort primarily what we end up becoming
- Zig Ziglar
i have two pc's, the 1 1/4 and 2 inch 18 guage, no problems in several years
just got the senco 23 ga, havent tried it yet
caulking is not a piece of trim
Scrit,
I have a Makita 18ga. 2" brad nailer and like it alot.
The BEST brad nailer I ever used was some generic lt.green model (a shade darker than Hitachi) that belonged to a friend. It never had a safety plunger and a nice small point. I wish mine didn't have a saftey.
I also used to use a Porter Cable that had a safety with the perfect angle for use inside cabinets. The angle allowed it to never shoot wrong.
gk
hi i do lots of fancy kitchen cabinet crown , rope and dental mouldings . i have a porter cable brad nailer only because it shoots up to a 2 inch 18 guage brad which i can use for some base mouldings at times .i whish i had all senco guns however that would mean more guns if i wanted to shoot a 2 " brad most sencos are oilless
i also have the accuset micro pinner which i love againg i bought that cause i could shoot upto a 1" micro pin which i rarely use 1 " maybe i should have bought the senco which shoots a 3/4 "
Crosscutter,
Off topic a bit...I have been using 18 ga Bostich for kitchen crowns and other misc kitchen trim. I have been looking for a better filler. I have used the "crayon" type filler sticks, and the stuff that is oil based putty that is colored. I always finish the trim beforehand. Not happy with either one.The putty looks different depending what angle you look at it, and the sticks don't seem real permanent.On the crown thats not a problem but lower it would be...
Any suggestions appreciated.
Bud
hi
if the joints arent tight enough i sometimes cope the back of the miter joint out a little with a coping saw the company that supplies our cabinets send a crayon and a matching stain pen just like kratmaid does. before i make the miter joint up i take the stain pen and stain the edges of both miters glue the joint & micro pin it
<before I make the miter joint up I take the stain pen and stain the edges of <both miters glue the joint & micro pin it
Great idea, will try that. I make my own doors and finish them and the trim so I have to go find the crayons for that particular color..
Thanks...
Bud
maybe i left out another trick .take the crayon and heat it with a lighter very lightly .
rub the hot melt into the joint & wipe it with a paper towel shortly after.
if to much is on the joint i scrap the joint with a plastic spackle knife or a wood shim
this all take time & hides any mistakes if proper care is taken when it is done
ps : buy the doors from conestoga !! forget pride lol
