I use a lot of quarter round bits in my work and I have found that I get at least 50% more use from a 1/2″ shank bit than from a 1/4″ shank before needing to resharpen. I ask the owner of MVP Sharpeners here in Houston about that and he said “I’ve been trying to tell people that for years!”
I use Amana bits and the two shank sizes cost the same.
Other tips –
Some collets vibrate more than others. I got 3 before gettin one that ran smooth.
Have a sturdy platform (router table) and go with constant even pressure and speed. After a while you can tell what feed speed is best for the type wood and bit.
Keep the bits clean. I take the bearing off and soak the bit in acetone or lacquer thinner.
Occasionally put some light oil on the bearing. Run the bit on some scrap wood to get rid of the excess oil.
I’ve never had any luck trying to ‘touch up’ a bit using a diamond hone. I usually get worse results afterwards.
Find out what grit your sharpening shop uses. MVP uses 600 grit and I get a much better edge than from the original sharpening by the factory.
For what that might be worth!
PlaneWood
Good tips. Thanks for the post. I've been a fan of 1/2" shank bits since I got a router that will accept them. I buy them exclusively now.
"Keep the bits clean. I take the bearing off and soak the bit in acetone or lacquer thinner."
Does soaking the bits remove the factory paint?
Tom -
Hmmm, well, I just looked at my bits and they have no paint! Now is that cause I washed it all off or did they not come with paint to begin with?? To my best recollection, Amana bits have no factory paint. Don't have any new ones right now to look at.
This is not an issue with me. After about 6-8 resharpenings my bits are ready for the trash barrel. I usually keep about a dozen bits sharpened and ready to go. Most of the time they set with the plastic goop coating on from the sharpening shop.
None of my Amana's came with paint either.John O'Connell - JKO Handcrafted Woodworking
>>"Life is tough. It's tougher if you're stupid - John Wayne"
John - did John Wayne invent that phrase or did some movie writer??
Don't know for sure, but it fits. Probably a writer.John O'Connell - JKO Handcrafted Woodworking
