I’ve made a four-piece (two ends, a seat, and a back) bench from 2-1/2 inch thick slabs of a cherry tree I cut down last month and have not kiln-dried. It’s to serve as a memorial in the woods to an old hunting buddy who died recently. The wood is green and I’ve left the bark on the edges. Can anyone suggest a non-staining chemical or finishing material that will slow the process of deterioration and help keep the bark from falling off? Will, say, spar varnish or exterior polyurethane even adhere to green wood?
Sorry to hear about your buddy. Chances are that cherry cut in the summer or fall will lose it's bark. The only time to cut down a tree if you want the bark to stay attached is in the winter.
Any finish that you add to it when it is this wet will most likely fail. Put some on, and refinish as necessary.
Good luck.
Jeff,
Thanks for answering my post about the green cherry. I guess I'll just slather the bench with spar varnish and hope for the best.
Edited 10/11/2008 2:04 pm ET by fenapple
You could always apply a heavy wax (parafin in mineral spirits?) to slow down water loss and minimize checking then finish next year.
Beer was created so carpenters wouldn't rule the world.
Weatherproofing the Green Cherry Bench
Jeff,
Here's the bench getting its annual coat of spar varnish. The bark's still hanging in there after nearly four years in the woods.
Thank you for sharing your project
A really nice bench. I am not a fan of bark left on but for this bench in this setting it is perfection.
i was knocked back on my heels to even consider putting finish on wet wood but look at that ! Worked out fine. Looks terrific.
