Well, after 4 years of apartment living I fianlly got a garage and can set my shop up again. My hand tools are a little dull, though, so I need to sharpen them. I have a bunch of King waterstones, and lo and behold, I never marked the grits on them. I have an 800, 1000, and a 1200. Anyone know how to tell the difference? Do I really even need all 3? I usually grind the bevel and touch up on the 3 stones and then use a 6000 grit to hone. Thanks!
i wouldn't waste my time with all three they are almost same grit... I use 1000, 4000 then 8000
If i had the 800 i would likely use that instead of the 1000
Herb,
I have an 800, 1200, 3000 and 6000. I wouldn't trade any of them. I find lots of occasions to use the 800 (in fact that stone is getting pretty thin). The 1200 is enough finer that I don't feel like I'm duplicating my effort. But from an 800 to a 1000 or from a 1000 to a 1200 seems to me to be a wasted step.
Alan
Speaking of cone shaped stones for the gouges, Woodcraft has a sale on right now for India stones at about $10, the Norton's are double that price (also larger) is it worth it? Also, they have med. and fine...can anybody guess what grit that would be?
thanks
Thanks to all who responded...does anyone know how to tell the difference between the 3 stones? They all feel the same on the surface. Should I just take the back of a chisel to each one and see how the scratch marks cancel each other out?
The coarser the stone the duller will be the result of a shapened bevel or flattened (polished) face. At the grade breaks you've got you might need a magnifying glass to see the differences in scratch pattern, but this is the sure way of identifying each stones relative coarseness. Slainte, RJ. RJFurniture
I would agree that a close (magnified) inspection should do the trick.
When you figure it out, let me know if you wanna sell off your 1000 grit stone....
[email protected]
Herb,
I'm not sure a magnifying glass is needed to distinguish between the stones. Even with my failing eyesight I can see the difference on my tools left by my 800 and my 1200 stones. I don't think I could see a difference between an 800 and 1000 or a 1200 and a 1000. So when you can see a difference it means the work came off the 800 and the 1200; the other stone would be the 1000.
Alan
