Referring to the article in the Dec 2006 Issue-Waterborne Finishes Come of Age by Chris Minick. What is time frame used for assessing apprearance of color. Just when it dries? Does that mean it will not yellow later? I see no way of contacting Chris Minick to ask the question. I am using maple and want to keep that light beautiful color as much a possible. I have tried the Hydrocote and have been less than happy–the satin is too glossy. They are sending me a “flattener”. I am also getting ridges. Hydrocote says that the Resisthane Plus is more for spraying so they sent me the Polyshield Clear Satin..
I had done a test of the General Finishes Product and it worked like a charm. I really see no yellowing on the maple–but I am concerned about yellowing in the future.
Thanks-Beauty
Beauty,
I didn't contact Chris Minick but I did move your question to Peter Gedrys's folder. He is a professional finisher and can speak reliably on the subject.
Regarding your question about yellowing, the test assessed the color after the finish dried. Maintaining the color for the long term is another issue. For example, if the piece is exposed to a lot of UV light (next to a window for instance) it is going to darken unless you find a product that advertises UV protection or keep it away from sun-drenched locations. Cherry is notorious for darkening over time. I haven't seen that to be the case with maple in my experience.
Matt Berger
Fine Woodworking
Matt-
Thanks for your input. I am trying the Hydrocote again with a flattening agent as it finished as a gloss.. Hope this will work well since the test said this will finish clear.
Thanks again--Beauty
Concerning yellowing over time; Staying water white or non yellowing is their major selling point.
Besides CAB Acrlic lacquer, it is your best option for a clear non-yellowing finish.
Peter
