I live in the united kingdom and plan to purchase my first band saw I have a buget of 1500 pounds
My question are there any UK woodworkers that can advise
I have been looking at the startrite products as a starting piont
regards Charnwood
Fine Woodworking Recommended Products
Festool Rotex FEQ-Plus Random Orbital Sander
The Festool Rotex is a top-of-the-line choice. On its coarse setting, it removed stock nearly twice as quickly as the second-fastest model. But that speed doesn’t mean you’ll have to wrestle with it. It’s no huge task to control it with two hands, and its long body gives you plenty of room to find a sweet spot while holding it.
Sketchup Class
If you're ready to jump into designing with CAD, this is a great place to start.
Oneida’s Super Cell Dust Collector
30-Gal with Wall Mount
Triton TA1200BS Belt Sander
Weight: 10.6 lb. Amps: 10 Variable speed: Yes Belt alignment: Excellent Material removal rate: Good Sanding flatness: Excellent Shaping/scribing: Very good Handling on side: Good Dust collection with hose: Very good
Marking knife: Hock Double-Bevel Violin Knife, 3/4 in.
This heavy, double-beveled knife stays on track in all directions, and works just fine without adding a handle.
C,
My bandsaw experience is limited to one Elektra-Bekum of the £350 type and my present machine, a Scheppach Basato of the £1500 size (12 inch resaw capacity).
I can't recommend the E-B as it seems they make their stuff down to a price. The guides were poor and it will cost you to put on ones that work properly. The castings under the table were white-metal, which fractured and made table-tilting difficult. The table itself was not at all flat. I believe a lot of their stuff is made in the far east but not by the better makers over there.
I can recommend the Scheppach, which is powerful (3HP in 2HP out)and well-engineered in Germany.
If you have a Scheppach TS or P/T then you can swap the various fences, mitre-gauges (not for the P/T obviously) and micro-adjusters around between the machines. This is very useful if you want, for instance, to quickly mount a fence on the other side of the blade from the normal side; or if you want to swap a tall fence-face for a short one; or one with T-tracks in it.
The guides are very good TCT discs and easy to get at/adjust precisely.
It uses cast iron wheels with very tough vulcanised tires, has a two-speed pulley and all the adjusters work precisely.
The Scheppach has one foible: dust collection is poor (but it is with most bandsaws, unless you make some sort of shroud or wind-tunnel in it).
Mine does a lot of resawing of hard stuff such as oak, teak and iroko. With a 1-inch 1.5 tpi hook-tooth blade it eats even a 12 inch plank of teak with no complaint; and accurately. It will leave a perfect 1/16" veneer slice from even a huge plank, if one sets up and saws properly. But it also serves well to cut the tight curves, as blades are quickly swappable & guides adjusted to, say, a 1/4" 6 tpi.
This week, it are been mostly slicing up large 1..5 - 2" thick, 8 - 12" wide planks of iroko and teak for Adirobdack chairs, then cutting the profiled curvy parts out to 1/16" of the templates edges......
Thank you to everyone for your replies
I think I will look again at the Scheppach Basato It was a saw I had initially considered but decided to look at the Startrite band saws believing they were made in the UK .I have now been told they are made in Italy
Ideally I would like to purchase UK made saw but sadly this may not be possible
regards Charnwood
I had a look under the bonnet (as you guys say) at a Startrite TS a few years back. Not the best machine available but certainly a good.. solid machine reasonabally priced I feel. I would have considered it for myself if I had access to it here in the U.S. I cannot recommend the SR BS as I have not seen it.
But... I can recommend comparing the various machines you do have available if possible as the machine will tell you what is your best choice on your budget. Some things are universal I believe.
Good luck...
Sarge..
It's one thing to have a budget and another to know what other tools you would like if you came in under budget.
I have an old startrite 14inch ex school workshop. There are things it will not do, but not the things I ask of it, and it cost me £600 some years back. I use metal cutting blades and it zips through oak, iroko, elm and so on, frozen meat and pies no matter how deep.
There is a good used tool stockist in Nottingham so why not make some enquiries? Also Bedford Saw & Tool Co people are very helpful re advice in my experience. Just know what you want the saw to do before you buy.
I've got a Scheppach Bassato 5.2 which has been great: plenty of power, 12 inch resaw capacity, good guides and a large cast-iron table. I would certainly buy it again. It will cut veneer smooth enough to be used with little or no sanding. Its only weakness is when using 1/4 inch blades (the smallest it will take) the guides don't give as much support as I'd like (they are the hardened wheel sort).
