I have a 10″” table saw a Record 250 but a cannot seem to get good accurat5e rip cuts as I get binding on the up cut as the wood passes through my blades are all sharpe and I get it whether I use a combi blade or specialist rip blade. I try and make sure my rip fence is parallel or slightly tilted away from the cut can you suggest anything I am getting very frustrated yours hopefully
GED MEAGER
What are you sawing and does the wood actually seem to be pinching the blade?
John White
I'm mainly sawing fairly soft pine ane the blade seems to spring back once i've pushe the wood through which takes a bit of effort
thanks for you help
GED MEAGER
Yes the wood does seem to be pinching on the blade as the blade seems to spring back when Iv'e pushed the wood through which requires some effort. The wood I use is mainly pine although, I have the same problems with sheet materials.
yours hopfully
GED
My guess is that you don't have the blade and fence aligned, although there are any number of possibilities. If the front rail isn't straight or the fence isn't always locking squarely on the rail the alignment will be different each time you move the fence. On some saws the entire top can be loose and shifting.John White
