Hi All
I’m about to start in on making a hollow wooden surfboard.
The deck is made up of 6 pieces of 1/4″ Paulownia (light weight open pored timber similar to Balsa) the boards will be edge jointed and glued up(Titebond 3) as per a table top.
This timber is very blond and I would like to add some color to a couple of the boards on the deck. The board will be finished with epoxy.
My main concern is dye/stain leaching out into the unstained boards after glueup.
Any thoughts/recommendations on a suitable product and are these concerns well founded.
John Walters
Is paulownia really strong enough for a surfboard?
My approach would be to seal the surface with a thin coat of shellac after whatever color treatment you apply.
Whatever you do, don't skimp on the experiments, of course.
Hi Steve
Thanks for the reply, the Paulownia only forms the outer skin the real strength of the board lies in a keel and rib system made of marine ply.
Lots of experimenting to come, will give the Shellac a try.
John
Hi John ,
Check out this site
http://www.vintagewoodensurfboards.com
A pal of mine is making surfboards out of wood as well , he bought a Redwood log and had it milled into slabs like 12' long 2-3" thick and 24" wide .
Traditionally Koa , Redwood , Fir , Balsa and a few others were used .
Also experimenting with hollow closed cell foam filled boards with torsion box like frames .
surfs up dusty
