At work Iv’e stained poplar with 120 orbital and then 120 by hand with great resukts.
Now, at home, even working through the grits, 100 to 220, I can’t have it take a stain evenly even using a pre stain. (the poplar has steaks)
Any suggestinos?
Any suggestinos?
I am sure you will not like my answer. I use poplar very often.. A bit soft but a wonderful wood to work with. I just wipe on some oil and wax and then leave it as any wood should be.. As it was grown!
I feel nothing unpleasant about wood in a natural state.
OK some oil and wax on top!
Edited 10/4/2008 4:02 pm by WillGeorge
I have stained alot of poplar too, and some times it is fine sometimes it is horrible. It all depends on the grain, and poplar being a wood where the winter growth and summer growth are not noticably different for example like pine.
I forget which growth is which.
I try to pick stock that has a tight straight grain, the peices that have the swirl or wavy grain often will look very uneven. I learned that lesson the hardway when I built a mantle for my home.
I also use a prestain conditioner when I stain. It seems to really help.
You could also try a stain then a sealcoat of shellac then a glaze to even out the streaks. Then a protective coat of poly. I am not sure if anything else is compatible with the glaze.
Webby
Edited 10/4/2008 7:09 pm ET by webby
