Well, I trimmed a tenon to fit a mortise that it didn’t belong going into (right hole wrong tenon), and well it is loose. For the life of me I can’t find any fixes in my books although I remember reading some.
I could always glue a small sliver onto the tenon, but before I do that I thought I would as “O ye find woodworkers” what is your favorite trick, so let me hear it, expand my knowledge, please
Dave
how about some veneer? assuming that the shape is ok(square, parallel etc)
Two choices. Well, three:
1) Glue thin wood, or veneer onto the skinny tenon, resize and assemble.
2) Remove the offending tennon, work a mortise in the end of the piece where the tennon used to be, and use a (properly sized) floating tenon.
3) Go to the woodpile, pick out a nice, new piece of wood and redo the offending piece.
All three choices have their respective merits. Your call.
Mike Hennessy
Pittsburgh, PA
I remembered for some odd reason I did make an extra peice, so I just used the new piece, however, I will keep the floating tenon and veneerin mind for next time.
thanks DaveChildren are our future, unless we stop them now -- Homer Simpson
Glue a veneer build-up or floating tenon.Or if possible, cut a kerf and use a wedge & tenon if it will work without splitting the wood.Greg
Exo 35:30-35<!---->
I would use epoxy, and mix additives to it to make it as thick as peanut butter, then spread it all over the tenon, and over-fill the mortise, so that the excess will have to squeeze out as the tenon is inserted.
I normally keep colloidal silica to thicken epoxy, but also add the dust from my belt sander to change the color to whatever wood I am using.
