Does shellac reach an age when it is no longer suitable for finishing? At the local hardware store there was Zinser shellac manufactured anywhere from May 08 to October 08; nothing made in 09!!
Zinsser claims a three year shelf life, though personally I wouldn't buy it after two. In Canada you're lucky to find it on the shelves -- I can't. A decent dealer will order it in for you. There's the option of buying flakes and mixing your own, but again in Canada that's an adventure if you want dewaxed. There's only one dealer that I know of, and he's as easy to contact as the fairy at the bottom of my garden. I order mine from TWW in the states.
Jim
Our local Home Hardware and Turkstra Lumber both carry Zinsser. I usually mix my own flakes -- from Lee Valley -- but felt a little lazy to-day.
Lucky you! I used to buy from LV too, but they've stopped carrying the dewaxed grades -- not enough interest I suppose.
Jim
I've used Zinnser shellac that was past it's expiration date by several months (and kept in a less-than-ideal shop environment) and it performed just fine. I'm not suggesting that you do that, but I wouldn't hesitate to buy it with the date ranges you specified.
There is a simple and time-honored test for shellac. Apply a coat to some wood. If it dries hard in 30-60 minutes, it's OK to use. The only issue with old shellac is whether it dries properly.Howie.........
t.y. for your comments. I found a can of shellac that was mfg'd. in Oct. 08 and it applied o.k. Interesting comment from Frenchy about diluting commercial shellac with thinner (denatured alcohol) I think the next time I use shellac from this can I will dilute it as it has a very thick consistency. I have a new post you may wish to comment on.
How much you want to thin depends on what the purpose of the coating is -- e.g., a wash coat? a finish coat? Brushing or padding on?? You don't want to dilute without a plan. I think, if I remember correctly, Zinnser comes in a 3lb. cut. There are instructions on the can for diluting to 2lb. or 1.5lb.
You can get some great information about choosing and using shellac at Jeff Jewitt's Homstead Finishing web site. Here are two articles, just for starters:
"Shellac -- A Traditional Finish Still Yields Superb Results"
"Padding Shellac"
If you don't yet have a really good finishing book, his Taunton book Complete Illustrated Guide to Finishing or Flexner's book Understanding Wood Finishing are (either or both) must-haves in the library, and would give you information about using shellac for its various purposes.
Another Jewitt book I found extremely helpful is Great Wood Finishes.
.....I'll see if I can find your new post.....
Edited 7/23/2009 2:00 pm by forestgirl
How do you dewax shellac made from flakes? Do I have to dust off the old still?
Regards
Shoe,Make up a batch -glass (canning jar), let stand for a day or so - after shellac flakes are completely dissolved. Wax will settle to bottom. Decant, pouring off shellac (clear stuff) and leave the wax behind. Do again in another day for any remaining. Not 100% but close enough for all practical purposes to use anywhere dewaxed is normally used. If doing buttonlac, will also remove a few more legs and twigs. :)Boiler
Thanks. now I can keep the still for it's intended purpose.
I'm guessing you don't have any revenoooowers up there!
Mashing it up down here boss!Boiler
Yup we got them guys but they are busy chasing other crops.My grandfather hid his under the pig pen. The RCMP couldn't smell the mash due to pig poop.Years ago they used to have one dog trained to sniff out still's, he was located about an hour away from were I live. They have a large population of middle European background farmers. Lots of places to make shine.
I've successfully used some really old shellac.. However I put twice as much denatured alcohol in it than the label recommends.
I even pulled some 80 year old shellac off a piano and just for the grins respread it successfully.
