I have a set of smooth rimmed fortstner bits which have served me well for the past 10 years. They really need sharpening. Can I do it myself, in such a case I believe I need a small round diamond file, or does any of you know a professional outfit that sharpens them. Thank you!!
John Cabot
The Complete Guide to Sharpening, by Leonard Lee, discusses Forstner bits in some detail. It's available from Taunton Press or Lee Valley Tools.
Dear Uncle Dunc,
Thank you for your very valuable suggestion!
John Cabot
I've always used a small flat file and the sharpened edge of the triangular tip of a 5" triangular file to sharpen true Forstner bits. I keep a set of brace shank Forstners handy for all my mortising and half-blind dovetail work ... they're great. Recently acquired one of the originals made by Benjamin Forstner himself. It has no slot through the continuous rim, simply a port up through the center for the chip/shaving to exit.
The rim is sharpened on the inside by scraping it. I shall try to locate some original instructions from Connecticut Valley Manufacturing (CONVALCO), the last known maker of true Forstners. People do not realize that those sawtooth bits with center points are not even related to real Forstners! I will post those instructions here when I can find them. Good luck,
John in middle Tennessee
Thank you for your help> I remember in the '60 and '70 that Convalco was the only American Manufacturer producing true Forstners, Mine are quite old and most likely produced in Austria.
Thanks again
John Cabot
