I read a biography of jonathan Browing the fampous firearm inventor. I said his father gave him a piece of salt cured wood to make the gunstock for his first rifle. Any idea what salt cured wood is
google with "salt dried wood"
I think SALT is any Mineral that they used.. I could be wrong..
Salting poorly dried wood is a cheap trick. As I'm sure you all know, Salt draws moisture out of the air. When freshly dried lumber showed surface checks before they had kilns with all of the bells and whistles, they would salt the surface, the salt would draw moisture out of the air, which would be absorbed into the surface of the wood, and close the cracks.
Now they would just add steam at the end to achieve the same results.
