I purchased a Bosch 3.25 HP Electronic Plunge Router
Model 1619EVS. I want to know if there is a router lift available for it I want to put it in a router table. ? The woodpecker plunge kit is it the best one as well as the only one out there, or are other companies out there.
Many thanks
Edited 5/5/2007 8:18 pm ET by anagab
There are several lift mechanisms available including woodpecker, Jessem, and Bench Dog. There are also a lot of articles and posts comparing them. A little searching should turn up a lot of material.
But, read the article in FWW issue #189 on routers for router tables. You can buy a router designed for use in a router table for less money than one of the lift mechanisms, without the router. Think it through. I am studying the same issues, and I am probably going to buy a router capable of top adjustment and bit changing, rather than a lift mechanism.
Best regards, Tom.
There is a long discussion on router lifts which started recently:
http://forums.taunton.com/fw-knots/messages?msg=35886.1
