How do I get the burn marks out from the round stoping point of my routed flutes.
Hi John,
Don't stop would be the easy answer. It would be the facile way out. Also it would be dreaming because sometimes you have to stop a cut. Sanding can work but it's tedious and prone to rounding your nice sharp corners. A good sharp gouge can work if it's the right shape. You could also try making a scraper out of an old saw blade or if that flexes too much, try and shape an old file handle or even a cutter from an abandoned Stanley #45.
But try this first. Make your cuts, get in and out of the stop as quick as you can. Clean your bit with a bit cleaner, an oven cleaner, or some kind of solvent. Then make the cut 1/32" deeper and again get in and out of the stop as quickly as possible. This might just do it. Good luck. Gary
