I am having difficulty removing random orbit marks from my work pieces. I am using a Festool random orbit sander and usually progress from 80 120 and 240 grit and the finish off with a 360 Abralon pad. Even so, I can still see the distinctive random orbit swirl marks. Do a need to hand sand with a block to help remove the swirls? Longer time with the finer grits? More intermediate grits?
Stan
Stan,
Right off the bat I'll tell you this; you are over sanding!
You didn't say what wood you are working with but I usually use a schedule like this;
120 if the wood is very hard like oak with a random orbit.
150 with a random orbit.
180 by hand.
Done.
On a rare occasion I'll sand to 220 but not often.
Use the abralon for it's intended purpose, rubbing out a finish.
Peter
Peter,
Thanks for the info. I am sanding tiger maple. I may need to add an intermediate grit. How much pressure should I apply to the sander? Simply the weight of the sander alone?
Stan
Stan,
I also have a Festool ROS and there is an issue with the vac setting on the dust extractor, if you are using one. You need to reduce the vacuum when sanding, or the vac will inhibit the motion of the sander. You can see this if you watch the motion of the sander while increasing the vacuum. At some point, the sander motion will visibly change as it gets "sucked down". This will definitely cause the swirlies. Also, skipping from 120g to 220g could contribute. I would use Peter's recommendation for most applications.Good luck, Tom.
Tom,
Thanks. I amd using the Festool vac and I did not know that. I figured the more vacuum, the better. I will try reducing the vacuum and watch for changes.
Thanks again,
Stan
