I’m finishing a cherry table and I seem to have put on too much linseed oil. It has formed a gummy coating on the surface. Does anyone know the best way to remove this? I was planning on trying to rub it down with a cotton rag dampened with mineral spirits.
Any ideas?
Fine Woodworking Recommended Products
Zissner Seal Coat
Great as a sanding sealer, and as a final finish.
- Initial static pressure (in. of water): 77 - Static pressure with bag 2/3 full: 75 - Noise level (db): 80 - Disposable filter bags (5 pack): $70 - Reusable bag avail. from mfr.: No - Hose length (ft): 13.5 - Cord length (ft): 24
3M Blue Tape
One of the most versatile accessories to have in the shop: from layout to seaming veneer. It has enough stretch to pull joints together.
SketchUp for Furniture Design
Foam Brushes
Foam brushes are great for applying a variety of stains and finishes, and the 2" wide brush is the most versatile. Comes in a pack of 48.
Don't wait. The mineral spirits will only work before it cures. I'd use a plastic pad with spirits, then rub down with the rag. If it's very thick, start with a scraper. Don't know how thick or how long it's been sitting. Once that's cured you'd need paint stripper or sanding to remove it.
Don't worry about taking off too much, as you can always add more later. However, if any of the gummy coating remains for too long, it's difficult to fix.
Bear in mind, there's no way to put on too much linseed oil. The key is that it is not a film finish, and all the surface oil must be removed in 10-30 minutes. You need to check it again in an hour or so, to see if any more has bled onto the surface, and rub that off.
Gerry
