A couple of years ago I bought a Primus #4 by ECE. It seemed like a good deal from the tests done in a WW mag. The mouth opening is adjustable but when I adust the blade to start planing it comes right up to the sliding part. I got no instructions with it and I think the blade goes bevel down. I know I am not too happy with it. It is too light but then again I have never used a finish plane before. Where can I get directions on its use and how all of the parts go together? I do not figure things out well just by looking at them and need some clear direction.
JT
Jerry,
The blade goes bevel down.
Is it a plane with the wooden wedge that is adjusted with gentle mallet taps, or does it have an adjuster - I think that the Primus/ECE planes have an adjuster that looks like a wedding ring on the end of a bolt.
If you let us know this bit, then I'm sure you'll get the advice you're looking for.
Cheers,
eddie
afterthought: Here's their instructions/blah blah.
http://www.ecemmerich.com/fertigungsprogramm.html
It has an adjuster. It seems as though the blade is sitting too far forward as if it had a spacer between it and the frog. I do not recall it have such little clearence when I first got it. Maybe I'll strip it down and put it back together to see if I screwed up when I had the blade out last. It is a Hock blade and I'm sure it is the same thickness as the original. But then again I have no idea where the other blade is.
JT
