I have just purchased a Porter Cable Pin100 pin nailer.
The pins end up flush with the wood surface. The instructions say to run compressor at 100psi which I have. There is no ajustment on these guns. Has anyone had this problem.
I have read on a review section that some users have ground back the Plunger/hammer to increase the stroke. Has anyone had success with this method
Regards
Forestbret
That's, the way the guns are designed (not to countersink). Both PC and Senco are like this, and if you want a gun that will countersink you will have to go with a better, more expensive gun from Cadex, Nikle, Grex, etc.
I know that you can slightly file down the Senco head, but I don't know about the PC.
Could you return it?
EDIT: I assume we're talking about a 23 ga pinner........
John Wooden 1910-
Edited 4/17/2007 10:55 am by nikkiwood
Mine sinks them about 3/32 below the surface.
My PC nailer is the brad nailer, using 16ga nails instead of 18ga. So I may be talking about a different model than yours. However, my nailer does have a depth adjustment control. I refuse to buy any nailer without one now.
My older Senco 18ga nailer / stapler doesn't have the adjuster and frankly, I use it a lot less because of it. With my Senco, I've found that playing with the PSI and how hard I press the nailer against the piece were the ways to control the set depth. PITA in other words... :-)
Another downside to the dual nailer / stapler was that I would typically see blow out for the full width of a staple when using brads.
Glen
Turn up the air pressure?
I just went out to the shop to inspect a project that I did with a PC100 pin nailer, they were set a wisker deeper than the diameter of the nail. Material was red oak. Were you holding the gun down firmly, and square to the material ?
You are correct too in respect to set adjustment, nothing in the owners manual. And as another suggested, I expect you could file .015 or so off the 2 ears but I would consult PC customer service before doing so. But would try firm pressure and square to the work first.
Bruce S.
There was a recent discussion regarding pin nailers on Breaktime last week. A lot of good comment there by guys who use their guns every day. One great tip I got was to pre-stain the pins before loading them into the gun. Use a colored marker and just hit the tops. The driven pins will then blend into the wood. I haven't had the opportunity to try this yet, but I can visualize the benefits.
Thanks for your response sounds like a tip and I will give it a try.
Regards
Bret
I just purchased the Bostich Pin nailer which handles up to 1 3/16 " pins, about the same price as the PC from Amazon. The Bostich has a depth adjustment, which doesn't seem to do anything, regardless of the setting. But all of the pins are driven just below the surface almost invisible. I found that if I press the gun too hard against the surface, the head of the gun left a mark, firm but gentle pressure seemed to work best.
Thanks All for your reponse
Regards
Bret
