Hi folks,
Is there a product that «Really» seals Knots in Pine that will be painted? I’ve used oil base primer (1 coat) and 3 coats of Latex paint, both of best quality and months later, Trace of knots started to reappear on my work! I’m desperate!
Shellac maybe? But under paint, what’s the procedure?
Any Idea? Thanks
JP Maher
Zinsser B-I-N, which is a shellac-based primer, is the best that I've found.
Thanks,I'll check if this product is available in Canada. If not I'll try to find something equivalent or import it!Thanks again,It a great community with no bordersJP
Bin is good, but if you can't find it or equivalent, you can use unpigmented shellac. You can tell the equivalent product by recommendations to thin with alcohol or to clean brushes with either alcohol (methylated sprits I believe in your neck of the woods) or household ammonia. Just apply, let it dry, and then repaint.
Yep, B.I.N. is widely available in Canada, at least in Ontario, in paint stores. What isn't so available is Zinsser Sealcoat, though you can order it. Following the advice of knowledgeable knotters, I've been using Sherwin-Williams Proclassic waterborne acrylic in place of latex, though in order to get that I had to go to the S-W contractors' outlet.
Jim
White pine is the first choice for exterior trim work here in Maine. Wipe the knots with paint thinner or turpentine to remove any sap and let dry. We spot prime knots, nail filler and other defects with two applications of either white pigmented shellac or a stain killing coating like BIN. After spot priming, we prime the entire surface with a good quality oil based primer. Top coat with two coats of your choice. We like acrylics.
This won't seal every knot forever. Next time you paint, do it again.
Pine is also our first choice of wood for exterior trim work here in Québec. Great tip hammer1. Thanks a lot!Jean-Pierre
Kingsbury, Québec
When I run into particularly tough knots to cover I use a three pronged approach... shellac sealer (B I N or sealcoat); oil base primer sealer (Kilz or other brands ); and acrylic cover coat. Very few problem stains will persist through these steps and for those rare ones which do another round of the same is finis! Most often I will use the sealers from spray cans because it is a superior way to cover and fast too. I will sometimes brush where spray would be too messy. If a knot has some cracks or pits I will fill them first with acrylic gel (I like Golden's "molding paste").
I agree with most here. I've had very good luck
with Zinser 1-2-3 pigmented shellac. I hit the knots
2 - 3 times (dry time is very fast!) and then prime the
entire piece.
Also - knots will eventually show themselves - but
it takes a while before they bleed through.
Bill-
Depending on the size and number of knots I sometimes just cut them out and plug. A bit of trouble, but it beats having to go over the same ground and knots that come loose are even worse. It depends on the aspect, full sun, shade and so on.
IMO, plain old dewaxed shellac.
Shellac, small knots one spray from a can. Large and porous knots a couple of spot sprays , let the first coat dry,usually under fifteeen minutes.Shellac will leave a shiny surface after painting if it is not scuffed with sandpaper ( 180 grit). I usually spray shellac on the entire piece. Then you do not need a prime coat.If you have a lot to do, spot spray then when dry scuff it lightly with sandpaper.Prime and finish coat.
mike
I'll go for shellac. I'm doing interior trim work in a old Victorian Cottage of mine and I want to match the plinth and other woodwork. Most of them are Pine. Some are painted (20 coats since 1858) some just varnished (shellack probably). In the new addition I painted Pine that was kiln dried. Polyprep oil primer and latex paint. But with all I read from all of you guys and «Thanks to all of you by the way», I'll go for multi-coats of shellac primer (Zimmer), easely available here in Québec, a good oil primer and latex paint!Great bunch! I'm proud of being part of a companionship like this one. Long Life to FWWJean-Pierre Maher
Kingsbury (Québec)
Canada
Sorry,
«Zinser» That is!!!
Jean-Pierre
JPierre,
I see you are just on the other side of Sherbrooke. I have a summer cottage on a lake in St. Hermenegilde. We've been to Sherbrooke & Coaticook many times! Great stores and restaurants, but I like Quebec City the best, just a bit far away.
Have fun here in Knots, they're a great bunch of folks to know.
Hi Bob,You're right. 25 miles from Sherbrooke. A great region as St. Hermenegilde too! The world is small as we say here! Québec city is the most beautiful city in the province and in the Country in my point of view! The old port, Le vieux Champlain, Rue St-Jean etc. And this year is the 400th anniversary of the city! There are a lot of activities and fun to have!Well, thanks for the mail,If you drop by Sherbrooke, email me before if you want to visit. Before June 'cause we're moving toward Hudson St-Lazare closer to Montreal with dogs and horses!J-Pierre
