I was wondering if anyone had a suggestion about how to make an interesting way to build legs into a vertical queen size Murphy Bed. I bought the hardware at Rockler but I don’t like the look that their method uses to conceal the drop down legs to support the bed. I would really appreciate any input on how this could be accomplished in an attractive way.
Thanks, Ronn
Murphy bed legs
Having built several murphy beds in our 1-bedroom apartment, the look of legs has never been very attractive. To add to my consternation the legs were not sufficiently sturdy. For our bed in the living room, I created a fireplace, complete with a bed-sized graphic of a tiled firerplace.....the illusion is quite effective!
The mantle shelf was cut to the proper depth and width to function as a very wide leg. The support it gives is superlative and with a bevelled, tilted mirror behind it, on the base of the bed, the illusion is quite complete.
I made wainscoting using an ogee bit for the solid cherry trim, inverting the rails on the router table. For the handles and legs I ran them through the ogee bit on all 4 sides using a coping sled and was very pleased with the results. The thin edge of the ogee shape so far has been strong enough to support the queen-size bed. If it breaks, I'll make a new one. I finished the solid cherry and cherry plywood with linseed oil, spar varnish and turpentine, then waxed it.
Whoops-I sent the wrong pictures. These are the right ones.
Hid the leg
I use the Rockler system and I hid the legs a few ways. One is to move the murphy bed legs to the outside edge and open up the front. Here is an example: http://wwbeds.com/excalibur.htm
Another way is to make the wall bed leg long. Here is an example of one like that. http://wwbeds.com/euro.htm
