I am tunes-up my table saw (10 yr Unisaw) with the help of the article by Roland Johnson (FW #179, p. 46). Despite using a degreaser (LPS F-104) and lubricants (LPS Force 842 Dry Moly Lubricant and LPS 1 Greaseless Lubricant) I still have a sqeak when I crank the tilt shaft. I think the noise comes from the front trunion as I start cranking the tilt shaft from zero to 45 degrees but getting better after a few cranks. Do I use grease despite the sawdust attraction it wll cause? Any more ideas? Thanks.
Grease will only create new problems. I use graphite (powder), and it works fine. Work it in for a while, and see if it goes away. If not, add some more, and work it in.....You'll get it, be patient.
mine squeeks too, I gave up after many sessions of attempting to hunt down the source and a cure. My Minimax bandsaw squeeks for about 1 second when I fire it up too, I'm thinking there may be some strange atmospheric phenomena that is centered on my shop.
I use a dry lubricant called "lockease" that is meant for locks. It is a graphite lubricant that I can buy at all the hardware stores. I use it for vise screws, tablesaw lead screws, and clamp threads. It is good for most screws, but not for the highest load screws that still need a good grease. Problem is that grease and oil always catch sawdust and turn to thick putty.
The Lockease doesn't pick up much sawdust but provides lubrication. It sprays out of an aerosol can with a WD 40 like tube (works great for lock too, but stains the door as it runs out). I don't like it as much as a product we used to use at work called "DGF" or dry graphite film. I don't seem to be able to find it locally although I haven't looked too hard.
Another lubricant I've used for high vaccuum was a teflon mold release. The teflon did a great job of lubricating threads also, but was also not a high pressure lubricant.
I lubed my Unisaw following the FWW #179 article and had to work in the lubes to eliminate all squeaks. The controls move very easy now. The dry moly lube is excellent for table saws as it drys and resists dirt and sawdust. Protect the inside of the machine with old rags as the lube is sprayed as it can make a mess since it contains graphite. I used Dri Slide moly lubricant, it is about the same as the LPS 842.
You're right about the mess. I'll keep on working on the TS until I eliminate the squeaks. It good to know that someone has gotten rid on all his TS squeaks!
Have you tried spray litheoum grease? I also get a squeal from my bandsaw on startup,solved it with the litheoum grease.
mike
