Hi. A few years ago I wrote down a formula to calculate springback based on the number of laminations, the thickness of those laminations and the radius of the curve around which the entire package is bent. Unfortuneatly, now that I could use it, I cannot find the formula. If anyone could help, it would be much appreciated.
rustum
I saw it posted here just last week. Check the archives.
JC
Here's one:
The more things change ...
We trained hard, but it seemed that every time we were beginning to form up into teams, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing; and a wonderful method it can be for creating the illusion of progress while producing confusion, inefficiency, and demoralization.
Petronious Arbiter, 210 BC
Here's another, perhaps handier.springback = R /( N2 - 1 )where R is the form's radius and N is the number of laminations
Is N2 supposed to be N squared or N times 2?
N squared, I don't know how to enter the little 2. :)I've not yet had a chance to put this formula to use but the results seem pretty reasonable.
thanks
Riff ---
I've seen that formula too. However, I don't understand what this springback is. For instance, is the difference in the radius from the form's radius? Or is it something else? Could you make a diagram which clearly defines this?
Hi Jamie, you've got it. As you said "the difference in the radius from the form's radius" or put another way the form's radius + spring back equals the final radius of the laminated part.
http://www.woodweb.com/knowledge_base/Calculating_Springback.html
http://www.woodweb.com/cgi-bin/search/search.cgi
A visual to go with it. Most of the answers are already out there if you know how to search. Thinner plies and a harder gue will eliminate the problem as well.
Edited 1/3/2005 7:49 am ET by rick3ddd
