<!—-><!—->Hello, <!—->
I just joined the group. I am a metal sculptor and I want to incorporate wood into my pieces as well as design some accent type of furniture. So my woodshop area is kind of growing and I already have a saw table, a band saw, a miter saw, a router and a drill press. Now, my next tool would be either a jointer/planer or a thickener planer. At first I thought that with the help of a jig I could do the jointing on my table saw, and do the rest on a wood planer; so I would buy the planer. Then I read that one has to get the “two sides” of the wood through the jointer first to get an effective use of the planer. If this is the case I cannot do the jointing of the wide side of the stock at the table saw; so I would need them both. At the end, I have been researching a lot on which one should be more useful, but I have found a lot of opposing opinions. So I am trapped.<!—-> <!—->
Because of my very small level of wood pieces production I will be buying most of my wood at the retail level where most of the wood comes pretty clean. Also, most of my designs will be small accent furniture, like chairs, coffee tables, end tables, and ornamental. Can you please help to decide what of the two tools would be the best for me at this point?
Thank you so much
Alfredo Alamo <!—-><!—->
Alfredo,
Personally I think the jointer is more useful than the planer. It can plane both faces and edges. If you're careful you can get a face flat and an edge square to it on the jointer and do the rest of your work using those as reference surfaces. The planer will only clean your boards and make a face parallel to whatever face you run down to the table. So if you send a cupped board through the planer, it will be pressed flat by the pressure of the feed rollers, planed, and then emerge from the planer with a recently planed but cupped surface again.
If your board is bowed it will stay bowed coming from the planer.
Get a jointer is my advice. Gary
