I recently purchased an older, used 12″ Delta Radial Arm saw. It has a magnetic starter with remote low voltage controls. That said, the transformer that drives the LVC is quite noisy, and no amount of tightening / adjusting seems to fix it. Just wondering if there is any way I can make it quieter. I have even heard of coating the transformer with shellac / or crazy glue to help lock the plates together…
Nathan
Are the laminations exposed?
Men will never be free until the last king is strangled with the entrails of the last priest.
~ Denis Diderot
No, but the transformer casing is bolted together (4x bolts), so I think it could be opened up to expose the laminations.
Using wooden wedges to tighten up the laminations is an old but often effective trick.
