Saw some huge winding sticks today but took me awhile to figure out what they were.The RR Co. CSX was replacing ties on the tracks in front of job.They have an amazing armada of very specialized tools that let them pick up whole rail .pull out old tie , put new one in; respike it and tamp ballast back under. They average 2 miles aday. One of last cars had 40′ trolley out in front of it with a cross arm and then cross arm in front of manned engine.Turns out they use it like giant winding sticks to make sure the rails are parallel and on same plane..engine adjust rail by picking up track section and tamping gravel under ties. What a racket this whole circus makes and not much hearing protection visible.
Interesting use for the winding sticks method !
roc
I watched a CSX crew work past a local crossing a couple of years ago. Very interesting. They have really mechanized the entire operation.
Frosty
The equipment uses lasers and computers rather than eyeballs to determine level. In addition to leveling track, it can accurately set superelevation on curves.
Don,
The construction crews capping the local landfill use GPS systems that have the engineers site plans to follow. The GPS tells the operator exactly where he is in relation to the proper elevation, slope, etc. according the plans. Cool stuff.
When we had our indoor arena resurfaced this spring, the Efficient Arena owner used a huge tractor with laser operated box scraper in the back -- laser on each end of the box, so the left/right ends operate independently of each other, scraped that arena floor down to purrrrrfect level (within 1/8") before putting the new sand/rubber footing end.
Part of what made it fascinating was how big the tractor was compared to the relatively small size of the indoor arena. I'm used to seeing laser-controlled stuff out in 1,000 acre farm parcels.
I guess the outfit was a nightmare to set up at first, hydraulics and laser didn't play nice with each other, and very, very temperature sensitive. forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Our oldest son sells the GPS controllers for construction equipment. The equipment has to "see" about six satellites to get the Z coordinate to the fine accuracy mentioned - thus when under trees, there is a problem.I first saw the equipment about 25 years ago. A contractor was bidding on a school athletic field; as he input the data to his computer, he discovered that if the 'base level' of the field was raised, the amount of earth to be moved was greatly reduced. The computer program had calculated and balanced the cuts and fills to determine an ideal elevation for the field.But - the operator will always be needed: if the GPS calls for a six foot cut, the bulldozer won't be able to handle it. The material has to be moved in bite-sized chunks. A similar problem arrises if the dozer blade is directed to a spot two feet up in the air. Can't move much dirt that way.Frosty"I sometimes think we consider the good fortune of the early bird and overlook the bad fortune of the early worm." FDR - 1922
