How valuable is an edge sander to you?
Well, I found one that is reasonably priced while I was considering the distribution of some woodworking machines (such as the jointer I put on Ebay a couple of weeks ago). I bought one for myself and I have one on Ebay now. It appears to do a wonderful job in tuning up door and drawer edges that I used a plane for. It is aggressive but one of the most controlable power sanders I own. I am betting that there are others that have been interested in these like I have.
Now, I have only had mine up and running in the last day or so, so I am not an expert. I would like to know of those of you out there that have these — how valuable are they to you?
Here is the one I have on Ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=4370810924&ssPageName=ADME:B:LC:US:1
"Q: Do you have a make and model # ?
A: This is manufactured by a Chinese tool manufacturer. The same manufacturer produces products for the more well known manufacturers and if you do a close examination, you will notice that some of them are identical in nearly every detail. Chinese quality has taken a large jump lately and this and the jointer I sold earlier are good examples."
Why are you selling stuff with no company name? No company name means no company support when it falls apart, right?
Molten
The distributor will support me on things that might go wrong. I had some feet on the jointer and the cap on the spring guard return that I had them replace. They did it with no problem. I had no problem with the edge sander. It was so well packaged that I think I could have dropped it off a building and been safe <:).
So --------- are you buying or selling the edge sander????????
I bought two, selling one.
I am confused by your post.
Are you selling this sander, or thinking about buying one?
He's certainly getting as much advertising in "under the radar" as he can, LOL!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Eric ,
I have an older combo edge / profile sander made by Rodgers Co. I use it when I make doors and drawers and to sand shelves . The small table on the left side of the picture you sent is mainly to assist with sanding curves or an inside radius . I use it constantly and rely on it to help clean up machine marks from the TS and jointer . I try and design my curves around the capacity of the sander . As Nikki was , I am also a bit unsure if you still had a sander or a jointer on E-Bay .
good luck dusty
Eric,
I have had one of these sanders for quite a while. It is not indespensable but I find it very handy, the tool of choice for final fitting of doors and drawer fronts because you can sand right up to any line, even a tapered one, with accuracy.
One thing I did add - on the far edge of the platform I made a stop, basically a wooden block 90 degrees to the paper. When fine tuning a door I like to have it rest up against that stop so I can concentrate all my attention on the above-mentioned line without exerting force to counter the motion of the belt. (Hope you understand what I mean). Just make the stop easily removable because sometimes like with a long board it gets in the way.
DR
Yes, I think I know what you mean. When I took the photos, I had taken off a stop that looks like a miter gauge that goes on the right side. I should have left it on, but I forgot.
You just confirmed my feelings about how it is going to work for me. I do a lot of drawers and doors. I have a feeling that it is going to be a lot easier with this tool. It looks like I have sold the second one I have. My reserve was met today. Do you have a good source for 6 X 80 inch belts?
Eric,
Yes I do but I'm afraid it won't help you much since I'm in Israel. Just by the way, this is the only machine in our shop that is not connected to a dust collector, and I'm going to have to do something about it soon. It sends dust everywhere in no time.
DR
After your post about the stop, I looked at the miter guage and decided that your wooden stop idea was something I should add. The miter guage does not come close enough to the sanding surface. I put an adjustable strip the width of the table on the right side and perpendicular to the sanding surface so I have a reference if I want it. There might be a time that I just want a point contact to the workpiece when I am not sanding perpendicular to a side, so I made the strip removable by using a couple of knobs with a threaded shaft to hold it down.
